Question about JVC AV-27D302 27" TV
JVC not turning on
Television has been working fine just stopped working....change plugs disconnected from cable....still nothing...not even a light or a click.......
    Genius:
  • JVC Master
  • 1,691 Answers
Power supply is dead. It may have been damaged due to other failures.
You can send the set for a repair estimate. But, personaly I would be shopping for a new set.
Jerry G.
Posted on Jul 12, 2008
6ya staff
SOURCE:
TV TURNS ON BUT NO DISPLAY AT ALL.
do a reset by manually holding down the power button, sometimes that works
Jan 28, 2014 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Sony Bravia was working fine last night and when I turned on this am nothing. The light is not on and the set won't turn on. The cable box plugged in the same strip works but the tv won't turn on. Not even...
Try unplugging set for approx 5 minutes or so, cross your fingers and re-try. Other wise sounds like power supply board failure. Some shops repair the boards others replace them
Jul 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Jvc rx-dv31 standby light comes on, but wont turn on, just clicks then turns off
sorry but this is an electronic malfuction or failure , it will need repair
leave it unplugged to prevent further dammage untill you can take it to your local electronic repair shop
electech
Oct 27, 2008 | JVC RX-DV31 DVD Player
TV won't turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 25, 2008 | Mitsubishi WS-65511 65" Rear Projection...
SBlinking green light
Have you tried disconnecting the power from the wall? Or power cycling your entire entertainment center? Possibly even check to make sure the VGA cable (or any other cable) didn't somehow come looose?
Jan 21, 2008 | Insignia LCDTV26 26 in. Television
SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Oct 21, 2006 | JVC TH-M505 System
JVC AV-27D302 27" TV Logo
120 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
