Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Cannot locate water filter eject button
We do not have the manual and cannot find a diagram online. Where is the eject button that ejects the water filter?
  • Anonymous Mar 24, 2008
    Julie was right on.
    The access is in the grill of the fridge. But you will have to really "reef" it counter clockwise to get it off. Mine required a fair bit of elbow grease. A small dribble of water will come out as well so have a rag handy.
    ***Some models do not have an eject button so if you can't find it use the twist method to get it out.
    Dan Canada
    President:
  • KitchenAid Master
  • 2,651 Answers
Your water filter is located in the kickplate area, you either have to twist it counter clock wise , or rightnext to the filter is a little button says PUSH. it ejects the PUR filter for replacement . ordering instuctions on filter itself
Posted on Mar 17, 2008
SOURCE:
How do you remove the water fliter because it doesn't turn and when i looked up the manual online it said to press the eject button but there isn't a eject button
i looked up your machine and you're missing the last two digits of the model number after the s but it shows that you turn the filter counter clockwise and then you pull it out,remove the cap,slide in the new valve,slide the cap on and turn it clockwise to install it.
May 23, 2011 | Whirlpool GS6SHEXNS Side by Side...
What is the model number for the water filter for the KitchenAid #KSRG25FKSS16 refrigeator and where is it found in the refrigerator? thank you.
Hello pssutherland,
I understand that you need to locate the water filter on your KitchenAid fridge. The water filter is located at the bottom of the fridge in the grill. There is a eject button that you will need to press next to the water filter in order to get it to release.
1. Press the eject button
2. pull the filter straight out
3. Remove the cap by turning it clockwise (you will need to install this on the new one)
4. Reinstall the cap on the new filter
5. Push the filter in until the eject button pops back out.
6. Purge the system run three full glass of water thru the water dispencer and throw away.
7. You are done
Thank you for choosing FixYa.com
Justin
May 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
Were is water filter in refrigerator
The water filter is located inside the fresh food section. In the top right hand up front as soon as you open the door it has a push button to eject the cartridge or it is in the back of fridge section in a plastic cup that easily unscrews. A new filter can be purchased at a hardware store or local appliance repair store. they can also be ordered online.
Oct 26, 2010 | Frigidaire FRS6R5EMB Side by Side...
Where is the eject button for a kitchenaid superba water filter?
I went through this same thing! You probably can't find an eject button because there isn't one on the model that you have. It probably isn't turning because it's just stuck and you have to just have confidence that you're not breaking it and force it to the left - all of a sudden, it will "pop" and turn easily.
Here is a great link to show you the different types of Kitchen Aid refrigerator filters - which kind has an eject button and which doesn't:
http://kitchenaid.custhelp.com/app/answers/detail/a_id/149
I also found a great (and short!) video from Kitchen Aid that really helped me see how to do it. Try this one - I thought it was the best:
http://www.kitchenaid.com/content.jsp?sectionId=852
Finally knowing there wasn't an "eject" button saved me many hours of looking, and the tip about using the handles of the plyers worked great.
It is really discouraging to think you can't just screw out a water filter, but it isn't you. The directions are misleading - they don't match what you're seeing, and it doesn't twist out easily - it has to be forced....and THEN it twists out easily.
Hope this helps. It worked for me when I'd completely given up.
Best of luck!
Eileen
Sep 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water filter does not eject when button is depressed.
I just had the same ting happen to me. You need to leave the cover to the water filter (it is the black plastic cover that is part of the grill) is still connected to the filter. After depressing the eject button, this cap helps to pull out the filter. DON'T throw away this very important part, other wise it is impossible to get the filter out. Once you eject the filter, some water will leak from the filter. Just put it in the sink to drain for a while.
Apr 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ejecting the water filter
rigth next to the filter itself "on hte toe grill" should be a spot marked "PUSH"
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Location of eject button for water filter
For more information or advice regarding water filters visit www.h2ofiltercentre.com it’s the best place I know to find affordable water filters and advice in the UK.
Call 01273 74 74 77
Can't locate the filter
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Filter is at the bottom of the fridge, in the grill, 6-8" from the left side.
Manual and parts list is available at http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=gs5shaxtl01&siteCd=WHRCOM
Regards,
MrBoo
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings. Be sure the
O-rings are still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
gaskets. Do not use paper towels, scouring pads, or other harsh
cleaning tools.
Nov 11, 2008 | Whirlpool Refrigerators
Water filter
Its on the bottom left of your fridge. 1. Press the eject button to release the filter from the base grille. 2. Pull the filter straight out. 3. Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 4. Align the ridge on the cap with the arrow on the new filter and turn the cap until it snaps into place. NOTE: You can run the dispenser without a filter. Your water will not be filtered. Simply insert the cap all of the way into the base grille and rotate the cap until it is firmly in place. 5. Remove the protective covers from the O-rings. 6. Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Jul 30, 2007 | KitchenAid Superba Architect KSCS25IN Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
633 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
