Question about Motorola Mobility H700 Wireless Headset
Passcode i need passcode for my bluetooth
    Sergeant:
  • 379 Answers
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Posted on Apr 06, 2010
  • 567 Answers
Usual code is 0000
Posted on Jun 07, 2010
If u pair more that 8 h/s the motorola wont allow u to pair any more
Posted on Apr 10, 2010
  • 787 Answers
The default one is "0000".
SOURCE:
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
    Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
    e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
    Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
    Jul 10, 2010 | LG GW300 Cell Phone
    Lost my book need passcode my phone is asking for passcode to install
    Well you can use 0000 it's the default passcode of your bluetooth headset. Most of the bluetooth headset use 0000 as default passcode.
    Good Luck!!
    Thanks for using FixYa!!
    Jun 19, 2010 | Anycom CC3103 PAROS-10 MINI BT 2.0 HEADSET...
    I need the passcode for my aeon smartduo bluetooth
    Check the manual that came with your aeon smartduo bluetooth device, it should have a section that shows how to connect to other devices and if there is any passcodes that need to be entered on the connecting device in order for a connection to be made.
    A common code for bluetooth passcodes is usually 0000.
    Hope I was of any assistance,
    Cheers :)
    Apr 22, 2010 | Cell Phones
    Passcode
    wats the passcode for a 9xx plantronics bluethoot
    Feb 02, 2009 | Plantronics - Bluetooth Headset Plus Base...
    Passcode for hands free parrot bluetooth device
    For the Parrot Minikit- that attaches to the visor. The default is 1234
    Dec 21, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
    Nokia 6233 bluethooth passcode
    The default passcode is either 0000, 000000, 1234, or 1111. If the bluetooth had a custom passcode set, you need to delete the profile from your device and repair the device with the bluetooth.
    Dec 16, 2008 | Nokia 6233 Cellular Phone
    Forgot my passcode for my bluetooth
    base on my experience on using the bluetooth on any mobile phone.. there is no permanent passcode in it.. you can set any passcode everytime you make a connection to another phone.. if someone you know sent you a file thru bluetooth the connection will ask a passcode from then you type any passcode then make sure you tell the sender what password you set on your bluetooth to make the connection..
    Sep 23, 2008 | Motorola Cell Phones
    LG Bluetooth HBM -500 Passcode for pairing
    I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
    Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
    Motorola Mobility H700 Wireless Headset Logo
    448 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Lawrence Oravetz
    Dennis Webber
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
