Question about Maytag Neptune MAH5500B Front Load Washer
MAH 3000 Maytag front loading washer-shuts down
Washer shuts down after only 5 - 10 seconds of run time and run light goes out.
  • 30 Answers
Check with Maytag (Whirlpool) board problem.
Posted on Mar 17, 2008
Maytag front load washer, MHW 3000 series, f22 error message
This is a problem with the door not locking shut. Maytag have an ecellent technical assistance page on this problem with diagrams and stuff. Go to:
http://maytag.custhelp.com/app/answers/detail/a_id/2889/~/display-shows-f22-or-fdl---front-load-washer
and take a look
Jun 30, 2011 | Maytag Washing Machines
Washer will not drain it is a kenmore top load all it will do is fill
most likely you have a broken drive coupler. not recommended to repair yourself
Jan 31, 2010 | Kenmore 23822 Top Load Washer
My maytag neptune washer will come momentaraly
There is a door locking unit that should lock when you press go. This must have failed. It lives just under the lid in the middle at the front. It is thermal piston, when you press go it gets power and extends. When it hits a micro switch that tels the washer the door is shut and allows it to continue, else it shuts down. To get at it you have to take the front off, leave the door on.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Error code d5 on front load neptune washer
d5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Neptune MAH4000 - Washer won't shut off!
sounds like to me you have a bad board needs to be changed
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune 7500 front load washer will not turn on when the AC or heat is running
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
Jan 02, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
570 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
