Question about Canon LV-S3 Multimedia Projector
Canon LCD projector LV-S3 won't start up and warning light turns on instead.
  • 3 more comments
  • lindenz May 01, 2008
  • PamCCRPC May 21, 2008
    Canon LV-S3 projector stopped working yesterday. Warning light comes on and that is it.
  • Anonymous Mar 26, 2009
    my canon projector with on warning light
  • Anonymous Mar 13, 2014
    I need to find a motherboard for my canon lv 7265 projector. Mine is fried and needs to be replaced
  • Anonymous Mar 29, 2014
    Terminal connection board burnt at VGA input section.. no values of CS 1001,1002,1003
I already found out the problem....
Maybe the fan or cooling machine of the projector is not working properly...try this
Face the back of the projector to the aircon or any cooling machine
at least 2 minutes. then turn on while facing to the cooler.
Hope it helps....
TAKE NOTE: Turn off the projector properly to avoid the same problem.
Posted on Jan 12, 2009
I want cheap projector
Posted on May 04, 2008
It sounds like the bulb is either blown or not properly seated.
Posted on Jul 28, 2008
SOURCE:
Purchase Canon LV S3 bulb
the Original lamp for LV S3
USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Apr 02, 2014 | Canon LV S3 Lamp
After some time warning light & projector shut down
The machine is getting too hot...
Used canned air like you would use on a computer keyboard to blow the dust and dirt out of the projector
heatman101
Jun 18, 2011 | Canon LV-S3 Multimedia Projector
I have a Canon LV-S3 Projector that has a blue discoloration that seems to grow after a period of being on, when left off for a while (30 minutes) it will shrink back down to a small 2" x 4" (W x...
What you describe is caused by heat from the lamp. That in turn is caused by either a very old lamp, (as the lamps age, less light comes out and more heat is generated), blocked filters, dirty fan blades/fan not cooling properly or contamination of the LCD units.
It is not recoverable and will, unless the fault is found, get worse up to a point of total lack of one colour. Usually the blue is the one that suffers most due to the UV light from the lamp turning into heat.
Dec 24, 2010 | Canon LV-S3 Multimedia Projector
Canon LV 5210's warning led turns red and turns off directkly after start.
warning problem related to lamp, already encountered that kind of problem replace the lamp assembly and it work.
Apr 12, 2010 | Canon LV-5210 Multimedia Projector
Canon LV-S3 casts a purplish cloud.
yes this happens all the time with lcd projectors, after a while lcd becomes distorted and bad,unfortunately you cant fix that (well thats what i know of anyway).
Jan 15, 2010 | Canon LV-S3 Multimedia Projector
SHOWING WARNING LIGHT
Most projectors show a warning light when the lamp is about to burn out.Your owners manual usually suggest that you replace the lamp before the burn out .
Oct 26, 2009 | Canon LV-S3 Multimedia Projector
Cannon LV-S4E when getting on it's telling "warning"
can u b more specific!
does the image come or not if it does does it go after a while
shyam
+919867355202
Feb 07, 2009 | Canon LV X2 Multimedia Projector
Warning light
Thanks for help .. I'm looking for Drivers & software Canon LV-S3
Nov 07, 2008 | Canon LV-S3 Multimedia Projector
Warning light stays solid on
The same problem as mine, is there a Canon technical support to help us fix this problem.
Dec 28, 2007 | Canon LV-S3 Multimedia Projector
Canon LV-S3 Multimedia Projector Logo
933 people viewed this question
Clive
Clive
old marine
old marine
Ekse
