Question about Epson PhotoFine P-2000 Digital Media Player
Epson P-2000 won't work on battery power
The Epson P2000 seems to discharge batteries immediately, even if not used. I thought my batteries had outlived their lifespan, so I purchased new batteries and the same thing happened. So then I thought perhaps the charger/power supply wasn't working, so I purchased a third party battery charger. Still having the same problem. I can put a fresh battery in, leave the unit sit over night and the next day the battery is almost completely discharged and can only be used for a couple of minutes. Has anyone else had this problem?
  • Anonymous Feb 17, 2009
    Had Mine for a year and now I have the same problem. Any one with help?? Epson???
  • Anonymous Mar 11, 2009
    Same problem, same symptoms. Mine is probably 18 months old.
Yes, the p-2000 is basically a pile of ****. epson dont do repairs, but offer a replacement for £170! rubbish product, rubbish company, no support! bin it - my second has done the same.... junk!
Posted on Sep 08, 2008
Mine is not charging at all...bought a new battery no difference.
Posted on Nov 10, 2008
SOURCE:
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
Tip
AC Adapter issues Q & A.
Laptop switching to battery while connected to AC adapter
Q. While turned on, the laptop will switch to battery power even if connected with the AC adaptor (sometimes during boot-up, or after a while) until the battery drains out, he then goes to hibernation (the battery light is off). If no battery in the laptop, it will shut down, and the AC light will blink very fast. The battery (li-ion) will only charge up to 10%, where it then jumps right up to 100%, and will discharge from 100% to 90% then jump to 0%, go to hibernation, and fails to complete the process, shutting down. The adaptor makes a small “camera flash charging” sound, stabilizing at 19v. When charging, it repeatedly makes the “charging sound” Faulty AC adaptor? Or Faulty battery? Or Both?
A. First problem: The laptop switches to battery power even with connected AC adapter. Most likely you have a faulty power jack. It’s either broken or loose. It’s a known issue with laptops and you can fix it by replacing/resoldering the power jack or relocating it outside laptop case.
It also could be a problem with the power cord. Find a multimeter and check the AC adapter. See if the power cuts off when you jiggle the power cord. If it does, replace the adapter.
Second problem: The battery will discharge from 100% to 90% and then jump to 0%. It sounds like a bad battery.
Battery charging light is on even when power adapter is unplugged and laptop is stitched off
Q.The yellow light for battery charging does not go even after switching the laptop off and power jack is disconnected. Battery does not charge at all with power source connected.
A. First of all, try reconnection the battery if you haven’t done it already.
The battery plugs directly into the connector attached to the motherboard. If the battery charging light stay on even when the power adapter is unplugged and the laptop is switched off, it’s either bad battery or something is wrong with the motherboard. The only way to find the culprit is testing the laptop with another known good battery.
Also, you can try this. Remove the battery and plug in the power adapter. If the battery charging LED lights up even when the battery is removed, most likely you have a problem with the motherboard.
Battery charges only when the laptop is off
Q. Bought a Laptop without AC Adapter. I noticed it would charge the battery OK when the laptop was off but once in windows it would not charge the battery.
A. This is very important to choose the right AC adapter for your laptop. The output voltage MUST be exactly the same. If your laptop requires 18.5V you must use 18.5V adapter. The amperage should be the same or higher. If the laptop requires 4.74A adapter, you’ll have to find an adapter which provides 4.74A or MORE.
While using AC adapter alone or battery alone, laptop works. While using them together, I am getting a problem.
Q. While using AC adapter alone or battery alone, laptop works. However while using them together, laptop LED lights blinks and the power meter for battery drops down immediately to 0% critical level, whereas the battery LED indicator says it’s full. I tried to unplug the AC adaptor while it went down to 0%, then the power meter for the battery came back to normal 85%.
A. There could be a few different reasons why it happens:
1. It might be an issue with the BIOS. Make sure the laptop has the latest version of BIOS installed, update it if needed.
2. It might be a software related issue. If you have some kind of power management utility installed try uninstalling it and use Windows power management utility instead. Also I would try reinstalling the operating system if upgrading the BIOS or removing the power management utility does not help.
3. If you still experience the same problem even after upgrading the BIOS and reinstalling Windows, most likely you have a problem with the motherboard. Apparently the charging circuit is not working properly. I assume it’s not a problem with the battery. You’ll have to check the motherboard in this case.
Problem with my battery. 100% to about 40% the battery discharging normally then suddenly from 40% it drop directly to 2%.
Q. When I use only on battery, from 100% to about 40% the battery discharging normally (last about 1 hour) then suddenly from 40% it drop directly to 2%.
When I plug the AC cord, it won’t directly charge (the charge LED is still not on). After 10 to 20 minutes it then starts to charge the battery (the indicator say that it can be charged to 100%).
If I turn-off the laptop and then charge the battery, it won’t also directly charge but the delay is much shorter (maybe just about 1-2 minutes).
Is this the sign of a bad battery (when hot it can’t be charged?) or maybe a bad AC adapter (not enough power to charge the battery when the laptop is turned on?)
Note that this symptom is always repeating when I use the laptop.
A. From the first part of your complaint description I can see that you have a bad battery. The percentage might vary, but the process of discharging is the same – the battery discharges fine until some point and then the remaining charge suddenly drops to the minimum. You’ll have to replace the battery.
I’m not sure about the second part. Probably it’s a battery related problem too. Just in case check if there is a newer version of BIOS available for your laptop. If you find one, upgrade the BIOS.
The battery is 100% charged but it will die within a few minutes as soon as the laptop is unplugged.
Q. When I unplug the power it will run off the battery, the battery icon says it is 100% charged and I have 2+ hrs remaining, but within a few minutes I get the “critical battery level” message and it will die. When I plug it back into AC power the battery charge light comes on (and will remain on for over a hour), but I will have the same problem with it dying as soon as it is unplugged. Do I need a new battery?
A. It looks like you have a bad battery. Here are some behaviors typical for a dying laptop battery:
1. The battery charges normally (according to the battery icon) but as soon as you unplug the laptop, it dies almost momentarily.
2. The battery charges normally. When you unplug the laptop, it discharges normally until some point and after that point starts discharging very fast. For example it might take 10-15 minutes to discharge from 100% to 80% and then it discharges from 80% to 0 for 2-3 minutes.
on Jun 12, 2010 | Computers & Internet
HP4530s battery dischargs when turned off
Remove the battery when the laptop is OFF. I am not good at electronics, but I think this is normal and is NOT A PROBLEM.
Jan 20, 2013 | HP ProBook 4530s Notebook
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
My ten year old Grundig Yacht Boy-------------------------------------------------------------------------------- When I play it on battery, it's fine. When I try to play it via an electric plug in the...
Probably more than $40 and that is the buy it now price on eBay at this link:
http://shop.ebay.com/?_from=R40&_trksid=p5197.m570.l1313&_nkw=grundig+p2000&_sacat=See-All-Categories
Note that the opening price is only $25. Suggest you get a "new" used radio as a cost effective option. Alternative: buy (now relatively inexpensive) NiMH rechargeable batteries and run your P2000 on them.
Ringbearers
Apr 04, 2011 | Grundig Yacht Boy P2000 AM/FM/SW Radio
HELP !! I have an Epson p2000 photo veiwer ... i
Hi Eric,
Sorry to hear you're have trouble.
Have you tried contacting Epson to help you?
Here is the User Manual PDF link, (click on PDF), that may be of help.
Page 56 & 57 might help you out.
Epson 2000 Multimedia and Photo Storage Viewers Other Products Support...
Good luck to you.
Andrew
Dec 01, 2017 | Epson Photo Viewer P2000 multimedia player...
Epson PhotoFine P-2000 Digital Media Player Logo
437 people viewed this question
Top Epson Audio Players & Recorders Experts
Tom Chichester
David Tickner
Bill Boyd
Are you an Epson Audio Player and Recorder Expert? Answer questions, earn points and help others
