Question about Texas Instruments TI-83 Plus Calculator
Only the on/off button works
When I turn it on all I get a dot screen, I can turn it on & off but no other button works
  • 4 more comments
  • em4may Mar 25, 2008
    i have the same exact problem!!! i don't know why but everytime i turn on the TI 83 plus, i get a dark, blank screen with pixels filled in. None of the buttons work, and the only ones that do, are the ones that turn it on and off. I've tried replacing the batteries, but it still doesn't work!!! please help, I really don't want to buy a new one. Thanks!
  • letmepokeyou May 02, 2008
    i have the same problem!
    i tried shaking it and then it worked like 3 or 4 times then it just turns bad again.
  • dustyjr6 Jul 17, 2008
    I am having what I think is the same problem. I have included a screenshot of what I see when I turn my calculator on. Only the on/off functionality works. 2nd -> Quit does nothing. Changing the contrast (2nd -> up or down) also does nothing.
  • dustyjr6 Jul 18, 2008
    Also, I have tried removing all of the batteries (including the backup), for varying intervals, up to 24 hours, and still nothing. I tried 2nd -> Mode nada. 2nd -> + -> 7 -> 1 -> 2 (reset memory) also did nothing.
  • Anonymous Jul 24, 2008
    Yes, the problem is same. Only on and off key works rest of others are not working.
  • engineeri328 Oct 28, 2008
    I have the same problem however if I turn the calc on and then type random numbers, then turn the calc off then on I get a fleeting view of the numbers before it returns to the black square. Tried contrast, graph and batteries with no success! HELP!
I have 5 dots that change position (only two positions) same problem, only on/off works. Ive taken out ALL of the batteries and still same problem....HELP
Posted on Apr 28, 2008
  • 3,037 Answers
If it is a screen with a pattern of dots then it might be in a graphing mode with a grid showing, does pressing 2nd quit do anything? Have you tried removing the batteries and the lithium battery and then putting them back in, let me know the outcome of these trials and I will try to figure this out for you
Posted on Mar 23, 2008
SOURCE:
The touch screen on my singer quantum xl-1000 lights up but no icons are showing. What should I do?
I have instructions for recalibrating the screen on an XL-6000, which is similar enough that it should work; however, give it a try at your own risk. I would point out, though, that at this point you probably have nothing to lose.
While the machine is turned off, you hold down the scissors button, reverse button, and the green/red light button all at the same time. While pressing these buttons, you turn your machine on and can let go of the buttons. You take the pointy end of your lint brush and use it as a stylus to touch a little red dot on the screen (that also has that pen looking thing that I had messed with and that caused my trouble), the dot will move to another position and you will touch it again. It moves again two more times, and each time you will touch it with the pointy end of the brush. Then you will touch the treasure chest box on the screen to save what you did. You will then turn off the machine and turn it back on, and then things work again!
Oct 19, 2014 | Singer Quantum XL-1000 Computerized Sewing...
Touch screen calibration
To calibrate the StreetPilot c-Series touchscreen, follow these steps: Begin with the device turned off and unplugged from a power source Power the device on and continue to hold the power button for 1 minute Release the power button when the screen displays "Press Dot" Accurately touch the dots as they appear The dots will change location A stylus or pencil eraser may be used to accurately touch the dots Touch OK when the "Calibration Complete" appears The touchscreen is now calibrated.
Oct 16, 2013 | Garmin StreetPilot C330 GPS Receiver
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
When I switch the device on it comes up with press dot screen
Have you tried a screen calibration? Turn off the unit then press and hold the upper left of the screen as you turn it on. A dot will show up on screen and then press the dot firmly as it moves around the screen. When it is done it will say screen calibration complete.
I also assume you tried a reset by pressing the reset button or on the newer units just hold the power button while turning it on for about 15 seconds until it reboots.
Thanks for using FixYa
Sep 25, 2011 | Garmin nuvi 1450 GPS Receiver
Comes up with press dot screen nothing I do seems
Touch screen does not work. have tried solutions found in trouble shooting but nothing works.
I also assume you tried a reset by pressing the reset button or on the newer 205's just hold the power button while turning it on for about 15 seconds until it reboots.
Sep 06, 2011 | Garmin nuvi 205W GPS Receiver
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Touch screen on hp laserjet m 3027 mfp not working
turn of the printer. Hold the C and # buttons and turn on the printer. When the screen goes black it will be ready to be re calibrated. there is a white dot, touch it with a pen, another white dot appears, touch it with a pen. It will continue to turn on now with a newly calibrated screen.
Dec 26, 2008 | HP LaserJet M3027 MFP Printer
Texas Instruments TI-83 Plus Calculator Logo
163 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
