Question about Gateway FPD2275W LCD Monitor
HP LCD Monitor no on and off light
I have a 15 HP Monitor LCD, the on/off switch is not coming on, so there is no power.
What could possibly the problem?
  • 5 Answers
It's probably a bad power board.
Posted on Mar 17, 2008
HOW DO I FIX CLICKING SOUND AND BLINKING POWER LIGHT IN COMPAQ MONITOR FP5315. THE MONITOR FAILS TO POWER.
the power transistor on the SMPS of the monitor is blown,
you will need a skilled person to diagnose and replace the component
Aug 29, 2016 | HP Compaq Fp5315 15 Lcd Monitor With...
Vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor: you mash the power button and the light will come ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
When i plug in the switch "on" my HP COmpaq LCD 15" monitor can not respond. black screen and the power putton light GREEN show but not display. after 1 minute the green light off. when i soon "on" monitor...
ysm7862001, Monitor has possible problem lighting-up cold cahtode fluorescent lamps that provide lcd panel with white light from rear(reverse side) of the panel. No white light= black or blank n black screen. Read my fixya profile for all options you might have open to you.
12fixlouie
Mar 01, 2010 | HP Compaq 1501 15" LCD Monitor
Power light or screen will not come on my hp w2007 monitor. It's only 13 months old.
Possible answer as I had same issue. I found the button you press has small tip that presses the actual switch to turn the monitor on. My tip broke off so switch can not be made. Hp does not sell button as that is what I am looking for myself.
Dec 13, 2009 | HP W2007 LCD Monitor
NO LIGHT ON POWER BUTTON ON HP PAVILLION f1703 DISPLAY MONITOR
knpeterso548, I wouldn't even worry about that little power "ON" indicator light. As long as the button functions as an "on" or "off" switch, you will only need to remember to turn sleep mode setting to total "off" mode (disable) in the pc. This way you will need to turn off the monitor with the BUTTON when you will be away from the pc for more than 1-2 hours. Face IT!!! Even I would charge you $15 just to open it up! $10 for a new "on/off" switch/with led and then $10 to put it all back together again. Give a call to HP (High Price) and find out what they will charge for replacing a switch. As long as the LCD panel displays brite, crisp images and text, you are way better off than those who don't see a thing on their LCD screen when they press the power "ON" button.
Bye for now. 12fix louie
Nov 05, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor will not switch on
your monitor could possibly have a backlight problem.. the wires to the lights are known to come off the lights in the screen.. if you try to check it your self be careful the lcd screen and lights are very frigile, nad can brake easly..
Oct 08, 2009 | HP w1907 LCD Monitor
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
Jul 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Have an HP LCD Monitor with a broken on/off switch.
j1hoo2, You will just have to go to YOUTUBE and search for things like::: lcd monitor disassembly or lcd monitor repair, or bad caps in lcd monitors, or repair of monitor SMPS/INVERTER power supplys. Yes!!! I have seen a couple of vids that show how to unsnap the rear plastic cover from the front bezel. That is the hardest part to do after removal of the monitor PEDESTAL. I'm louie12fix on fixya, or lmistyrel@ aol.com
ps I've also heard that really dull table knives may work and also an old credit/swipe-card might work also.. I mean did an elephant step on the monitor on/off button???? Come-on, their not supposed to FAIL !!!
Apr 24, 2009 | HP L1520 15" LCD Monitor
My hp 1502 has a problem.screen is white,but LED not lighted.
You need to replace the bad electrolytic capacitors inside.
Monitor Mike
Apr 14, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Power supply for Compaq 1501 15" LCD Monitor
the connecter of monitor will not fit wrong way it can fit only right way so no possibility to damage the monitor
Oct 28, 2008 | HP Compaq 1501 15" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
