This problem should be removed because:
Problem with Sewing Machines
How do you make a buttonhole with a Bernina 830?
Solutions (2)
Best Solution
Hey, I have a Bernina 830 Record. If it's the same machine, set your stitch length at 0 then back it off about 1 to 2 turns. The middle button is your button hole. Got to one and it goes down the left side, #2 is the bottom cross bar, #3 goes backwards up to form the right side of the buttonhole and $4 is the tack across the top, #5 stitches it into place. I have my original manual if you have any other questions!
Donna/Portland OR
Do you have a button hole maker on the machine? It's usually marked by the top bar and side bars. If not, you need to start with a zig zag stitch, and ensure the stitch is as close together (or short!) as you can make it.
The first set of stitches will the top of the button hole, so make them as wide as you want it. You then need to adjust the width to about a third of the original bar, and take this down the side of the length of the first bar.
You then make a bottom bar the same width as the first so you should have a kind of squared off c-shape. You then go back to the smaller stitch and join the two bars together to make you button hole shape.
You should have a small gap in the middle that you can then open using a quick unpick or similar.
Suggested Solution (3)
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps, I know it will.
Source: Bernina 830 won't zig zag, won't buttonhole, no decorative stitch
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Okay, my first take—because it fills bobbins "just fine"—is that the needle bar may be loose. You didn't specify what the service was for: was it just a clean and lube, or did you have a problem? Even with just a clean and lube, the needle-bar height may have needed adjusting, and the tech may not have tightened it securely. Does the needle bar move at all? even just a quick **** or two? If it acts like it is trying to move, but doesn't, that is probably the problem.
Now, here's the bad news (always seems to be some of that with these kinds of things, eh?): That needle-bar height is critical, and it's not something I can just tell you how to do here. The second bit of bad news is that the problem wasn't discovered for a year, so any service warranty is long expired, by now (unless the owner or manager of the store is your bosom bud, or, you are one of his/her best customers).
The good news is, if the shop is reputable, you could return it to them, explain what happened, and ask how much they would charge just to adjust and secure that needle bar (although the machine could probably use some more oil, by now—because it has just been sitting, which is harder on them than if you use them regularly). If they are like the shop I worked for, they will be glad to give you a slightly discounted rate to preserve their reputation, and hopefully, your business relationship with them. They may even throw some oil on it for the same price.
One more bit of good news, the Bernina 830 is one fine sewing machine. It is worth fixing, if any machine is.
Hope this is helpful, and happy sewing!
Ken
Source: Bernina 830 stuck
Bernina Buttonhole foot #3A
My Bernina buttonhole foot #3A for my 1130 has stopped working. I tried cleaning the lens but that didn't solve the problem. The...
Bernina 830 won't zig zag, won't...
I only use the machine a few times a year, mostly for straight stitching. 2 years ago I had the same problem and to fix it, I took it in for...
Bernina 240, won't complete the buttonhole
Bernina 240, brand new, won't complete the other side of a buttonhole, it just keeps stitching in place.
I have a Bernina 830, the older original one which
I have a Bernina 830, the older original one which is not computerized. My zig-zag does not engage.When I turn the knob selector, it turns...
Add Your Solution
Riccar quick cord release
How do you operate the quick cord release
how do you operate quick cord release on RSL5C
Hi! Singer 1862, sewing machine of brazilian...
Hi! Singer 1862, sewing machine of brazilian production! How can I find or may be ordered from manufacture the new...
will not accept voucher no.
spreets voucher no 1325066 redeem your voucher no 1-973-152 unique code HVAW9PA86N PIN 8288 Have tried all no's...
Fix-O-Meter
241
241 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
