Question about HP Compaq nx6110 PC Laptop
1780 disk 0 failure message
My laptop is about 1.5 yr old and the optical drive no longer works. I have not fixed it nor do I even try to use it as it causes the system to crash. Now the computer stops intermittently and I get an error message : 1780 disk 0 failure or 1781 disk 1 failure. I have to go into to setup and try different options to get it to start again. Once it's running its ok, it's only if I leave it for a while and it's in standby with a program running that it reboots to the error message when I start it up again.
It is a HDD problem or optical drive problem. HP website says optical drive other people say HDD - help!
    Genius:
  • 3,587 Answers
It's hard drive...most likely you are in need of a tune up.
check out this link, and you may find the Tuneup is just what you need.
Posted on Mar 17, 2008
Dell pc computer keeps freezing and crashing-have spoken to dell they keep telling me fixed but it is not
May be u need to reinstall a fresh copy of windows.or if u already done so, then it might be a hardware incompatibility
Mar 15, 2012 | Dell Computers & Internet
My Acer Aspire 5742 developed a screaming high pitched buzz. This happens even when it is not connected to the net, or even when there is no dongle attached. This has developed since we used a Virgin...
High pitch buzz is usually caused by the system fan but can also be caused by the optical drive and the harddrive. check if the system is getting hot. try cleaning the vents of the system. verify that there is no disc inside the optical drive. try booting to safemode and check if the system will still caused the noise. also run a hardware diagnostic to check the fan and harddrive.
Mar 27, 2011 | Computers & Internet
Can not get sound through surround system from the tv
check to see if yr plugged into line out,on tv.its usually [on sony]an optical out.go thru the input setup on yr amp,on the GUI,and switch tv input to OPTICAL,usually OPTICAL 1.try that
Jun 12, 2010 | Audio Players & Recorders
What does Operating System not found mean?
If you see this message during power on start up then there are two possibilities.
1. The computer is trying to boot from a drive other then the internal hard drive. Optional bootable devices include:
a. optical drives (CD/DVD/Blue Ray)
b. thumb drives (memory cards, USB drives)
c. external hard drives.
To correct this problem then remove the media (CD, DVD, Blur Ray, memory card or external hard drive) and restart the system normally. The computer should boot into the Operating system.
2. The computer's internal hard drive has been corrupted and the information required to boot the operating system is not readable. There are few different reasons for this including infections and hard drive failure.
If this is the case, please seek professional services to rectify the issue as serious infections and hard drive failure are problems that require advanced tools and methods to fix.
Feb 05, 2010 | Microsoft Computers & Internet
The HD on my Toshiba A135-S4827 crashed. I bought
I see a couple of possibilities here.
  1. The replacement drive is not the same size as the original and the wizard is looking for a drive that size.
  2. There is also a possibility that the error is causes by bad RAM (0A-0543-0000 is a read write error) if you have more than one RAM module try the wizard with one module at a time, see if error is isolated to one or the other module or slot
  3. The Restore CD is dirty/scratched of has a flaw in the original write
  4. The optical drive is defective or dirty
So things you can try:
  1. Clean the media you are trying to restore from.
  2. Clean the optical drive with a drive cleaning CD.
  3. Swap Ram as suggested, replace defective if necessary (OS install is about most RAM intensive process you run on a system)
  4. Try a manual Windows install from a Windows CD not a image restore cd
  5. Try a drive the same size as the original
Oct 21, 2009 | Computers & Internet
Not reading discs of any type
You will need to disassemble your Ps3 and see if you can adjust the blu-ray laser focus...or try to buy a new bly-ray optical lens:
http://www.diytrade.com/china/4/products/4913589/PS3_KES410AAA_Lens.html
Good Luck !!!
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
In my laptop dvd is not dedecting. Can u give me the solution.
You can make some changes in Registry, but before we do that , when you getinto REgistry Windows>Click on File and click on import and save the files some where, you are done with that :
Perform this :
n order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318} - delete upper filters and lower filters which ever you have. It should work out.
If not you reseat the optical drive and check.
If not you have a good known Drive, you can try swapping the drive with the known good unit>If the drive does not work on diff unit>Its an issue with the Optical drive and you can replace the drive.
Let me know
Jun 29, 2009 | Dell Inspiron 1000 Notebook
Aspire 5670 2 yr old it just crashed and stopped working
i think some damage has caused to the battery circuit. that si the reason why it is not even booting up. please take it to some authorised service center and get it checked.
Jun 11, 2009 | Acer Aspire 5670 Notebook
T40 intermittently crashes and recovers "from a serious problem"
If you have not upgraded of changed your power supply, you probably should. Also, you could be having troubles with your RAM. Have you try to perharps repair or re-intall window?
Let me know
Apr 13, 2009 | IBM ThinkPad T40 2373 Notebook
Laptop Crashes Only when Plugged In!
That is not a lot of space for the computer to operate, especially depending on if windows is managing a page file for extra memory, which it does by default. Delete as much data as possible, maybe get more than 10GB of free space. Also, try running the laptop by itself and see how long it will run with just the desktop showing. If it will run for a considerable longer amount of time that way, I would say that the free space is the issue......keep me posted...
Mar 08, 2009 | Sony VAIO VGN-S360 Notebook
HP Compaq nx6110 PC Laptop Logo
1,854 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
