Question about Black & Decker BL5000 ProBlend Work Top Blender
Buttons click but it won't run.
It has power, but pressing button only makes clicking noise. Tried to service but can't get plastic gear that engages blade to come off. What is the trick?
  • 3 Answers
I had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Posted on Jul 22, 2008
My cusinart cj e-500 is not working at all. I press the on/off swicth and NOTHIN!
One of the safety switches isn't engaging. Make sure there isn't a piece of plastic chipped off the bowl and the top cover is fully engaged.
Jan 21, 2017 | Blenders
The power light on the Ninja Blender flashes and will not turn on.
Make sure the pitcher lid is assembled properly aligning the arrow on the lid with the arrow on the handle. Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja will not run if the lid is not assembled correctly & the handle is not fully engaged.
Sep 28, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
How to repair motor
If the motor is running then the fault must be with either the clutch on top of the motor or the blade clutch it engages with.
Aug 30, 2014 | Breville BBL600XL. 5-Speed Blender
Two buttons are stuck in on my kitchen aid blender.
I have been searching for an answer to this same problem. My chop and mix buttons were stuck and I was getting no power or blinking lights. After finding no help on-line, I decided to take it apart and fix myself. It was easy and it worked!
1. Take the bottom of the mixer off by removing the rubber foot pads and remove the exposed 4 screws.
2. Remove the 3 sets of wires that are attached to the inside panel with clips. Very easy to remove, just squeeze at the base of the clips and pull up.
3. Remove the 2 screws holding that panel in place and gently lift off.
4. Remove the panel found under the top panel by also removing 2 screws. When you flip this panel over you will see what operates the switches.
In my blender the black plastic nubs that push against the buttons that were stuck and got twisted off kilter so they were not resetting properly. I just put a small screwdriver in there to try and straighten them as much as possible. All of these steps will be obvious as you disassemble the blender.
5. Push on the back of the buttons that were stuck to get them unstuck before reassembling everything back together.
I was surprised how easy a fix this was and how obvious what the problem was when I opened the blender up. No soldering or fancy tools needed, just 5-10 minutes and a phillips head screwdriver!
May 21, 2013 | KitchenAid KSB560 5 Speed Blender
Why wont my kitchenaid foodprocessor start?
Take the bowl off, turn it on in the centre at the front where the base of the handle would normally be there is a light coloured button/plastic piece. Push it in with a matchstick. If the motor now starts then you have a problem with the safety switching mechanism in either the bowl or the lid. It is more often the lid. The only solution is to replace the faulty part. Easiest is go to a service agent and buy whichever part solves the problem.
Feb 26, 2013 | KitchenAid Kitchen Aid KFP715OB - Food...
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Kitchenaid Blender Classic
Same thing happened to me. Opened it up and along the red wire to the motor is a bass fuse. Went to the hardware store and then I replaced it. Works fine.
Apr 12, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I have a Kitchenaid blender model KSB5BU3 marked "Ultrapower" and "Electronic Control" on the side. Suddenly all the buttons started blinking together after we pressed the On button and then one of the...
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Jan 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Will not work
First ensure that the blender jar is placed on the right orientation, othherwise the blender wont start.
Remove the Jar and place it on the other way if you are not sure.
If you still get the click, try leaving the blender power cord unplugged for a while. The click means that the blender has power, but the motor is not starting.
If it still does not work , and the jar is in the correct way and you did the above, then the blender is faulty, probably a faulty motor, or a broken wiring.
Dec 19, 2008 | Krups 574 Power Xtreme VI Premium Work Top...
Blender has lost top two speeds
With my blender, some of the buttons stopped working, and I found a simple way that fixed it like new, with no special skills or replacement of parts. To determine if this fix will work for you, unplug the blender and press on each button. As you do this feel and listen for a definite 'click'. If you here it for the buttons that are working, and not for those that aren't, you probably have the same problem.
I discovered that there is a tiny mechanical push button switch under each button. The switches are held snug to the bottom of each button by a thin metal bracket. If you have heavy fingers, the force of pressing the buttons over time, causes the bracket to deform, moving the switches further and further away from the buttons until, eventually, no matter how hard you press, they are no longer close enough to depress the switches underneath.
The solution is to simply open the blender (with the power cord removed) and gently push the button assembly back towards the buttons. To get inside you need to pull out each of the four rubber feet, and unscrew the phillips head screws that are hidden under them. Next, seperate the top and bottom sections by gently pulling the power cord through the strain-relief (don't worry, it goes back together very easily). Before putting it back together, check the buttons (always with the power cored unplugged !!!) for the 'click'. If this doesn't work, you may have to take out the two screws that fasten the bracket to the blender, and bend the bracket hold-down tabs with a plier, in the opposite direction of the switches (that way when you put the screws back in, they'll move towards the buttons. That's it.
Hope this helps someone like me save about $150.00 for a new one and keep another 10lbs. of junk out of the landfill.
Nov 08, 2008 | KitchenAid KSB5 Ultra Power Work Top...
Black & Decker BL5000 ProBlend Work Top Blender Logo
524 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
