Washer does not spin
The washer fills up and does not agitate, spin or release the water on any other cycle.
  • frognut Apr 18, 2008
    washer fills with water but will nut agitat.
    It just sits there.
    I installed a new timer but the same result.
My washer machine worked long enough to fill up with water and now it wont spin, rinse, or nothing. it makes a hummimg noise when i put it in spin like it wants to work but wont
Posted on Apr 28, 2008
  • 30 Answers
Lid S/W
Posted on Mar 17, 2008
4 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: Washing machine won't spin or agitate
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 29, 2008
SearsTechToo
  • 261 Answers
SOURCE: Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Posted on Oct 08, 2008
TheMobilian
  • 8205 Answers
SOURCE: why wont my washer agitate
must be worn out dogs
Posted on Apr 22, 2010
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    The washing machinge is not completing the complete cycle
    Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    As washer was on final spin cycle it sounded like a belt came....
    Apr 01, 2009 | Kenmore Washing Machines
    Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Washing machine doesn't agitate
    If washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. Note: direct-drive washing machines do not have belts. 1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn't, the belt may be loose or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) Call a repairperson; there may be a problem with the controls or the agitator solenoid may be broken.
    Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
    Washing Machines Logo
    392 people viewed this question
    Top Washing Machines Experts
    Richard Roth
    Richard Roth
