No audio on Aver tv usb 2.0 analogue, M026.
Please can you help. I can't get any sound when i watch tv on my laptop, even though every thing worked fine before i updated the driver from the aver website. I have installed it a few times but still no sound, either from separate speakers or laptop speakers. I would be grateful for any assistance.
Best Regards,
M. Klatschok
    Scholar:
  • 117 Answers
If it worked before you updated the driver, so a system restore to the day before you downloaded the driver. That will set things back to the way they were before the driver update.
Posted on Mar 17, 2008
Panasonic CF-VDRRT3
Check your connections and cables. From the look of the thing it is designed to work from the USB port on a desktop computer, a laptop gives less power through the USB ports, this is why most USB powered devices for laptops have 2 USB plugs for connection.
Oct 02, 2013 | Computers & Internet
Hi, I want to know if there is a way to watch tv (sound & picture) with a htmi cable or similar even if I do not have a hdmi port. thank you
You might be better off with external speakers connected to the laptop's audio output. Flat panel TV speakers tend to be weak.
If you want to continue with the HDMI option and your laptop doesn't have an HDMI port, try a USB to HDMI adapter. Look carefully, some models output 720p not 1080p. One possible unit: http://www.walmart.com/ip/Aluratek-AUH200F-Aluratek-USB-to-HDMI-1080p-Adapter/16386417 . However, your video rate may be sluggish due to the limits of the USB port. (If you have a USB 3.0 port on your laptop and find a USB 3.0 adapter, it won't be as bad. USB 2.0 adapters are more common.)
Look at the specs for your laptop or add a comment with the make and model. My mom's HP laptop (purchased in 2009) has an HDMI out; however, the audio driver doesn't go to HDMI out by default.
You may need to adjust the audio output options. (In Windows 7, Start > Control Panel > Hardware and Sound. Then Select Manage Audio Devices under Sound. Check the Playback tab for your audio output options and change the default device if needed.
I hope this helps.
Jan 17, 2013 | Computers & Internet
I have my television, cable box, and apple tv running into the tuner with HDMI cables with the tuner hooked up to surround speakers for the sound. I'm having trouble separating the audio and video. I would...
The only way you can do this is by connecting the Cable Set Top box HDMI directly to the TV HDMI input and switching the TXSR508 to Apple TV. And if you want to hear the Cable sound through the TXSR, connect analogue audio out of the TV to one of the analogue inputs of the TXSR ( Aux or Video In ). You may not get the Cable TV's Dolby 5.1 sound but you will get stereo sound which on using the TXSR's dsp setting ( ProLogic II ) can be made into 5.1.
May 04, 2011 | Onkyo TXSR508 Receiver
I want to know how to connect my lcd 32" tv to my new ht-c550 so that i can watch tv and listen to the sound of the tv through the surround system, what do i need to plug and where?
Not enough info here. But basically, the Audio Out from your TV (could be Toslink fiber-optic or Digital Coax or just Red and White Audio cables) go into the receiver's inputs (either TV, or Aux or whatever). If you just use the Red and White cables (stereo), you will not get true surround sound though. Just put your receiver on whichever one you hook it to (ie: Aux) and whatever sound is on the TV will come out the Stereo or Surround Sound. It's all a matter of hooking TV out to Stereo IN. Hope this helps; James
Apr 17, 2011 | Samsung Audio Players & Recorders
I am using an internal TV card model "Aver tv go
I am using an internal TV card model "Aver tv go 007". recently I have changed the Intel motherboard of my pc with an Asus motherboard. Sound is not available now. It shows "no suund card is available"Please help mr.RegardsMamun this is my problem
Feb 25, 2011 | Avermedia AVerTV GO 007 Plus/FM Plus...
I have a Toshiba laptop L305D-S5895 and a Toshiba Hi Def LCD 37AV502U tv. I got an audio cable, that I have in the headphone spot & the original cable needed to connect the pc to the tv. I am getting all...
Which cables have you attached to your TV (the video and audio)?
Does the TV has left & right audio inputs (RCA connectors)?
When you attach a headphone to the laptop, the speakers on the laptop switch off and the sounds divert to the headphones. Try and connect a cable (stereo) from the headphone outlet on the laptop to the audio stereo inputs on the TV.
Mar 28, 2009 | Toshiba Satellite L305D-S5895 Notebook
No audio on tv channels but perfect on DVD playback etc
this looks very much like a problem I once 've had (and later found the solution by accident). When you go into the menu of the remote control and press the "automatic channel search" function you can always specify from which "source" the signal is arriving either 1, from antenna, (ie. over air) or 2, from cable or 3, from satellite. Then the decoder searches and finds a bunch of station in its reach. Once (while hooked up to an antenna) ,I had accidentally made it do the station search under the "cable" header instead of "antenna" and it found the same stations as the one's I've had before,(over antenna) but some stations suddenly had no more audio. Because I was unaware that the set was programmed under the cable header I could solve this strange mystery only much later when I reprogrammed it one day and it searched the stations under the Air-Antenna header, then suddenly all the stations were coming in properly, with good image and full audio. ------If this doesn't solve your problem then search under the menu of your set if at another part of it you can specify some other similar options like Antenna-Cable choice. I'm quite sure its easy to correct. good luck Alex
Mar 26, 2017 | LG DBRH197H DVD Player/HDD Recorder
RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Sep 27, 2007 | Televison & Video
Computers & Internet Logo
547 people viewed this question
David Payne
David Payne
