Question about Magellan GPS
Magellan Maestro 4000 Audio Problems
I have a Magellan maestro 4000 that is 4 months old. The sound recently stopped working so I installed a memory card and upgraded the firmware to 2.36. The sound worked but was spotty at best. I called tech support and rebooted several times to no avail. The sound is not working most of the time, and when it does work it is shaky. Do you have a work around?
Mattie5000
The one i have is 3 month old and im having the same problem, the audio is not working (magellan model 3225)
Posted on Oct 13, 2008
6ya staff
SOURCE:
Magellan maestro 4000 no sound
I did an update on a Maestro 4000 and it seems that I lost my sound.
Mar 09, 2010 | Magellan Maestro 4000 GPS
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Nov 09, 2009 | Magellan Maestro 4000 GPS
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
Oct 09, 2009 | Magellan Maestro 4000 GPS
I have a magellan maestro 5310 which I have had about 4
press and hold the power button for up to 10 seconds. that should reset it. after you do that, go HERE and download and install the latest update for your 5310
bill
Aug 26, 2009 | Magellan Maestro 5310 Car GPS Receiver
Magellan Maestro 4210 no audio or garbled sound
I suggest you take it back to the seloloer before the warranty expires
Jul 20, 2009 | Magellan Maestro 4210 Car GPS Receiver
Magellan Maestro 4000 will not hold a charge longer than 30 min
replacement battery at http://www.xtreamgadgets.com/product.php?productid=132797&cat=10001980&bestseller
must remove external card from slot before removing 4 screws at rear of unit. cover snaps off, unplug speaker wire, unplug battery, new battery plugs in, reassemble.
Dec 27, 2008 | Magellan Maestro 4000 Handheld GPS...
Magellan maestro 4250
I have owned the Magellan Maestro 4250 for 6 months and the black cloudy spots just surfaced.  After talking to the Techs at Magellan (800) 707-9971, they advised me to send it into the factory for repairs.  Hopefully the one year warranty covers it.
Apr 15, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan maestro 4000, 4040, 4050 vs mio c220,c230,
Don't buy a Magellan. There is little to no support, and their web based support redirects to no where useful for upgrades. I'd sell you my 4040, but can't in good conscience sell it to anyone.
Nov 13, 2007 | Magellan Maestro 4040 GPS Receiver
GPS Logo
378 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
