Question about Sony Playstation 3 (PS3) Console
Over heating Getting really hot and freesing
  • Anonymous Mar 21, 2008
    IT over heated and started freezing and the games have nothing rong with them
    Sergeant:
  • 319 Answers
That's an oxymoron and completely against the law of physics. Nothing can get so hot that it freezes!
Posted on Mar 17, 2008
SOURCE:
I have a Toshiba now my issue is its getting hot really fast changed the battery so now don't shut off but now it gets hot. Any help? Please
Getting hot where? If you bought a generic battery it may not be compatible, The heat location is important. It could be the fan is dirty or the heat sink is not working well. Hard drives also get hot. Go to almico dot com and download speedfan and it will tell you the temps.
Jun 23, 2016 | Toshiba Computers & Internet
What else can I try, my Intertherm water heater is not heating water off the lower element?
I should like to hope I have your answer.
If yours is like most U.S. model, it is called a 220 volt unit.
That is not really 220 volts, it is really 2 separate 110 volt units.
What that means is, there are actually 2 separate 110 volt hot wires to the water heater, usually one hot wire is black, and the other hot wire is red.
One is for the upper heating unit, one is for the lower heating unit. Perhaps your lower unit has blown the circuit breaker for that line.
I mean the circuit breaker in the main fuse box/circuit breaker box.
Did you test the lower wiring to see if the hot wire is hot?
If it is hot, be sure to test the ground wire, and also the wiring between the bottom and the top of the heater inside it.
God bless your efforts.
Jan 04, 2018 | Water Water Heaters
Whirlpool Refrigerator neither cools nor freese
Have the model number? Can you feel the top of compressor to see if clicking or getting hot trying to start? 3_5_2013_2_17_27_pm.jpg
Sea Breeze
Nocking on refrigerator anywhere and starting is a loose or defective connection like a defective thermostat will cause these symptoms.
Mar 05, 2013 | Whirlpool Refrigerators
Heat not hot
Have you checked your heater hoses to see if they are both getting hot? If you do and only one is getting hot (really hot) then you may have a clogged heater core. Also you AC/Heat valve may be malfunctioning witch may be the valve or a vacuum issue. Really need more info to help.
Jan 26, 2013 | 1993 Cadillac Fleetwood
Phone getting hot
Your phone getting hot is a very normal thing. Mobile devices now are getting more powerful and dissipating heat using copper only goes so far. It's natural for your phone to get hot during usage, when playing games etc. But if your battery gets really hot, i.e. could cause burns or you feel that it's much hotter than it's supposed to be, please get it checked on, battery malfunctions may cause harm.
Nov 02, 2012 | Samsung Galaxy S 4G Cell Phone
My 1993 sl2 saturn its over heating i already change termostat and replace anti freese they gave me the green one so i mix it with water bt it still over heating the fan works only when i put on the a/c...
It could be the water pump. To check this:
  • Make sure the engine is not hot and open up the radiator cap.
  • Turn on the car and let it idle with the cap off.
  • Allow the car to warm up.
  • When the engine is hot and it is getting close to overheating, look down into the radiator. The coolant should flow. (It should look like a little river is going past the radiator opening). If the coolant appears to be still then your water pump is bad.
Other possible problems:
  • Bad coolant temperature sensor.
  • Air bubble in the cooling system.
May 25, 2011 | 1993 Saturn SL2
The floor on the driver side of my 1995 Landcruiser Advantage gets really really hot when driving
This may be caused by simple the heat of the motor. Your transmission is under your seat as well. Is your engine getting hot? Temperature going up? Check your transmission and coolant levels as well. These are just a few possibilities.
Jan 13, 2011 | 1995 Toyota Land Cruiser
My ps3 Keeps freezing after a short period of time
Your ps3's GPU graphic processing unit may be getting to hot cuasing the freese very commen in the first gen units the fix is going to cost you can have it fixed at www.videogamerepair.com there good and do exactly what there advertise so you will not have any issues.\\
Thanks I hope this was Very Helpful
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
Over heating
Is it really overheating or is the GAUGE reading hot. I had the same problem on a 72 Cougar and it turned out to be the sender. If it really is getting hot after all that the check the rad for blockage. Dan
Aug 06, 2008 | 1983 Chevrolet El Camino
Sony Playstation 3 (PS3) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
