*#7780# use this for resetting the phone.. which ll format the phone memory
You can do it in two ways.
Select the memory card and then select on options and then select format, it may ask for a password type it and press ok and you are done.
Second, you connect your mobile with a pc. select connection type as mass storage and you will see that it will appear in the computer as mass storage. right click on it and click on format.
A window will pop up and then again you have to click on Ok/Start and there we go.
SOURCE: how to formate phone memory of 6303
There is 17 MB in my 6303 but it does not shows .It always says phone memory full delete some items but there is nothing in my nokia 6303.please help
SOURCE: 6303 Cell Phone: I have nokia 6303 classic on 02 network uk but I w...
YES YOU CAN TAKE IT TO MOBILE SHOP IT COSTS 10POUNDS
SOURCE: my nokia 6303 phone shows itz phone memory is
hi...
please do the following
1.Make sure your phone is fully charged.
2.Backup your contacts list and personal files to MMC memory card (if possible).
3.Switch on your S60 phone.
4.Press and hold these three keys together:
5.Press the power on/off to swtich off the S60 phone. Do not let go the three keys until you see the “formatting” screen displayed
6.Wait a few minutes until the format is complete. Your S60 will now be at its original factory settings.
thanx
SOURCE: how to format phone memory of nokia 6303 classic?
my set nokia 6303ci problem is misse call one nember (8001697355) delete thies nember my set is restate and hange
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 6303 file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
