Nintendo Wii Console
Problem for Nintendo Wii Console
To connect WII on line
By janice3083 on Mar 17, 2008
i am using the telus enchance wireless networking and i have two computers that can access to the internet at the same time. when i try to get Wii on line, the error code is relaint to wireless security. i dont know how to locate the WEP WPA key.
thanks
Janice
vancouver, bc
Same Problem
Apr 07, 2009
-   same problem, has always worked so far but now it just won't connect, it detects wireless Tiscali, but won't connect.-   Guilloumes
Apr 20, 2008
-   i'm trying to connect to internet but keep getting error-code 51030- can you help me?
i have a wireless internet connector and my WII is right next to it but it still dosn't work!
please help me-   Guest
Mar 18, 2008
-   keep getting error code 51330 when trying to connect to the net-   peregoodoff
Solution #1
posted on Apr 09, 2009
Not Rated)
janifar7190
Rank: Master
Rating: 75%, 6 votes
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge............
Was this helpful?
Yes
No
Solution #2
posted on May 07, 2008
Not Rated)
larkin71
Rank: Wiz
Rating: 88%, 67 votes
try to set your channel to either 1 or 11.set also your router's broadcast setting to 'mixed'.place your wii near router with no interference from microwaves or such.if router setting is set up to allow only selected pc's (or mac addresses),don't forget to include wii's mac address to enable it to have access to the router.if your router password type is wpa,make sure also you know whether it's wpa-psk AES,wpa2-psk AES or wpa-psk TKIP,you need to consciously choose the right one on your wii internet setting.also,you could switch the dns ip addresses around like put 2nd ip address in primary and 1st ip address in secondary.the wep or wpa is your router's password type,either you already created it or not.granting you did (or someone in your household did,ask that person for the wep or wpa password),and can't remember it,check on the manual of your router or call their customer service on how to trace it on your pc and use it to on your wii's internet settings.
Was this helpful?
Yes
No
Solution #3
posted on Mar 17, 2008
Not Rated)
Glaceon
Rank: Apprentice
Rating: 0%, 0 votes
if you have the mannual for the telus enchance wireless conector it should be in there but if you haven't got the mannual or if it's not in it, call up the servies number in the book and if it's not in it look it up in the phonebook.
hope this solved your problemo
good luck
***Glaceon***
Was this helpful?
Yes
No
Popular Solutions for Nintendo Wii Console
Questions and Unsolved Problems for Nintendo Wii Console
Do you recommend Nintendo Wii Console?
Answer
Answer
I have a new WII and can't get it to work. I'm using a Sony TV and a Sony VCR --- WII pluged into... (More)
Answer
the unit comes on & shows disc to be played, but none of the 4 controllers will operate the... (More)
Answer
You see I enter into the main wii system then click on my game that I wanna play I yet when i go to... (More)
Answer
Our Wii will not play any games and tells us to refer to the operations manual
Answer
even with fresh batteries the wii keeps saying connection is lost with wii fit board can u help... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nintendo Wii Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
