Question about Jensen VM9020TS Car DVD Player
Can't hear right speakers
Whenever I play a cd you can't hear anything from the front and rear speakers, but when I play the radio all speakers work. Can you help me out?
  • 7 more comments
  • Anonymous Mar 17, 2008
    sorry forgot to say you can't hear anything from the front and rear right speakers only the left.
    yes it does
    IB4G2008 you there?
    wat do you mean dvd setting enabled?
    under the dvd setup theres a language menu, audio, surround fx, video, surround setup, and rating
    ok well it's not letting me select the dvd setup menu right now. So I will have to get the head unit repaired?
    to tell you the truth I wouldn't be able to tell you because I had installed it at an audio shop
    ok well thanks for all your help. i'll just take it back so they can check all the wiring because it was working just all of a sudden it just didn't so i'm guessing it might be something within the head unit itself
  • Anonymous Mar 30, 2014
    No matter how low or high the volume is that static noise is there. Hopefully someone has the solution this this problem. Thanks in advance
    Genius:
  • 3,587 Answers
Ok...got it..so..is your player have a stereo option for the DVD..can you make sure that's selected?
Posted on Mar 17, 2008
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Mar 17, 2008
    yeppers..
    so, is the dvd stereo setting enabled?
  • Patrick Michaels
    ok..surround setup...use that one, and if not there, use the audio..this dvd should be driving both sides, and only reason is due to this setting OR the internal connection is gone(which means a trip to the repair center)
  • Patrick Michaels
    are all these connected properly??
    Preamp Outputs: If you want
    6-channel theater-style sound, you can hook up the appropriate external
    amplifiers and speakers to the front, rear, center, and subwoofer preamp
    outputs. When the unit is in 6-channel mode, you can independently adjust the
    level of each speaker.
    Inputs and Outputs
    Notes
    6-Channel Audio Preamp Outputs:
    This unit has six audio preamp outputs: front left and
    right, rear left and right, center, and subwoofer.
    Headphone/Multi Zone Output:
    The Headphone/Multi Zone
    output consists of left and right RCA audio jacks and an RCA composite video
    jack, allowing you to connect an
    optional back seat monitor and headphone
    system.
    Aux Input:
    The Aux input consists of left and right RCA audio jacks and an RCA
    composite video jack, allowing you to connect external equipment to this head
    unit. You can connect the device directly or through the iAUX3 Auxiliary Input
    module.
    Video Out: This
    RCA composite video jack allows you add another external monitor.
    Camera Input: This
    RCA composite video jack allows you connect an optional rear view camera.
    Wiring Harness: The VM9020's
    main wiring harness has multiple Molex plugs that plug into the back of the
    unit, plus a large white 18-pin plug on the other end. The white plug should be
    cut off and each wire spliced to the appropriate wire in the vehicle wiring
    adapter.
  • Patrick Michaels
    ok..well..that's where you'll need to take it next..these are quite sophisticated boxes
SOURCE:
2007 cierra ,my radio cones on but not putting power to speakers except to 1 front speaker and it has almost no sound ,up full and very screechy . do I need a new radio ?
Sounds like a wire is shorting out, probably in behind the stereo, but more likely in the back where the speakers connect. Check for something shorting out or a wire grounding out near the speaker.
You can trace back from there.
Other than that probably is the stereo.
Dec 01, 2014 | 2007 GMC Sierra 1500
Fader/sub/speaker not working properly
I'm not an expert but often people connect subs to normal speaker wires in back of the radio. You need a dedicated subwoofer line so high frequency sound doesn't go to the subs. Only bass. Sounds like it wasn't wired properly.
Aug 26, 2017 | Pioneer DEH-P6000UB Car CD/ MP3 Player
Car front two speakers arent working. rear two are.
have the front speakers ever worked?
if not have they been connected properly?
if yes then
look under ballance and check theat rear and front ballance is in the middle
if it is then for temporarily replace the front speaker with any old speaker
if that works then you need new front speakers
if no then the radio is broken
but what you could do is rewire the back speakers so they also play though the front ones too
this can be done from behind the radio
find the rear right positive and negative wires
strip the insulation but dont cut the copper wire
cut the front right speaker and attach that to the rear speaker wire
do this for both positive and negative
rear right
positive
..v
..v
I...I
I...I
I...I
.I.I..........< strip cable but do not cut metal
.I.I..______________
.I.I=_______________ <<<front right positive
.I.I
I...I
I...I
I...I
I...I
Jan 06, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
On playing a store bought cd, left front speaker doesn't play, but right front does, currently there are no rear speakers all wires are connected through the wire adapters to hook directly up to the...
if its working with the radio the fault must be the cd part of the radio hence take it back after testing different cds, home made cds may not be compitable with unit
Jan 02, 2010 | Alpine CDA-9856 CD Player
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
I am putting in a cd player and i don't understand why it won't get power. i hooked it up staight to battery and it works just don't know which wire is power from the fuse block
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/White
Radio Switched 12V+ Wire: Red/Gray
Radio Ground Wire: Black
Radio Illumination Wire: Blue/Red
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Oct 01, 2009 | 1995 Jeep Cherokee
Install a cd player
HERE YOU GO ALL WIRES U NEED PLEASE RATE ME GOOD LUCK WILL WORK GOOD!!!!!!!!
2003 Ford Focus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: None
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
Aug 14, 2008 | 2003 Ford Focus
Stereo theft
try this to see if the right wires are there it normally cost about 130 to get a professional to do it
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 25, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Eclipse headunit
There nay be a wiring issue with your amp. When you are running a CD more power and sound quality is envolved so the amp works harder. Check the amp make sure everything is where it should be.
Feb 11, 2008 | Car Audio & Video
Jensen VM9020TS Car DVD Player Logo
90 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
