Question about Palm Treo 755p Smartphone
Beam I am trying to beam some info from one Treo 755 to another 755 and it is not working, message says: "could not find a receiving handheld computer".
  • Anonymous Mar 17, 2008
    Completely locked up. Wont reboot when battery removed, stays at the access powered screen
  • Palm Master
  • 13,434 Answers
Reset both devices and make sure the IR ports are alinged together so that they are in direct contact with eatchother.
The IR should work 0-10 meters id suggest 20cents from eatchother.
Posted on Mar 17, 2008
SOURCE:
Message that high beam is not working, but when you turn the key to 0 position and then turn on the engine, the high beam works again until you get the message in service that is not working but in fa
Hi fernando
The bulb check system in Mercedes is very sensitive to ( bulb watt ) I am sure there is problem with the headlight bulb it self also the parking light bulbs, I advise you to change the bulbs, this will sort out the problem.
Good Luck
Mar 20, 2014 | Mercedes-Benz Cars & Trucks
Having problems beaming data into memos. The system beams correctly into contacts, however, when I try to beam into memos, it only wants to receive it into docs to go. how do I change it to go directly...
have you tried soft reset? or may be hard reset but before this just make sure you backed up your data. It will revert back to default settings.
Apr 12, 2011 | Palm TX Handheld
Dropped my Palm TX, IR no longer works
I went to the Palm support website. It seems that after any reset, including a soft reset, the Beam Receive function has to be re-enabled. Follow this path:
  • Applications==>Prefs==>Power
  • Beam Receive==>Off==>On==>Done
For more information: http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,CASE=obj(14838),ts=Palm_External2001
I also updated the driver for my Palm wireless keyboard.
http://www.palm.com/us/support/downloads/universal_wireless_keyboard.html
Cheers!
Nov 25, 2008 | Palm TX Handheld
Bluetooth for ringtones
instead of bluetoothing them use your beam option just go to the main menue and click on the menue key (it is a button) them go to beam that should work
Nov 15, 2008 | Palm Treo 650 Handheld
Not receiving some of my text messages
I also have a Treo 650 that works flawlessly. I'm on AT&T and sometimes a message gets delayed but I don't think I've ever missed a message. I would believe it is the verizon network. It could also be effected by sunspots and the part of the world you are in.
good luck
Nov 14, 2008 | Palm Treo 650 Handheld
My palm treo 600 has a serious issue.
Ok this problem is very common in 600`s i have good and bad news
first go to the phone application and phone info
see what hardware u have A B C
A&B are toast and nothing can correct the problem
if your in hardware C your in good luck
bad news my first treo had this same exact problem and i had to replace it:( BUT BUT BUT!! it was caused by a 3rd party program that messed would auto reset my treo everytime it came on unfourntely uninstalling it didnt work and the wireless mode never came on..
got my second treo and had the same problem but i did not hot sync and intsted beamed using infared all my data and the problem never occured but sometimes
Aug 10, 2008 | Palm Treo 600 Handheld
Treo 755
Did you ever figure this out? Mine is doing the exact same thing now.
Aug 01, 2008 | Palm Treo 755p Smartphone
Beaming
Go to settings, connections and run beam.
May 20, 2008 | Palm Treo 750 Smartphone
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
Can not switch to phone function
Dit you try a soft reset on the phone?
Sep 15, 2005 | Palm Treo 650 Handheld
Palm Treo 755p Smartphone Logo
166 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
