Question about Kitchen Ranges
Oven Freestanding oven/stove won't ignite. Stove works fine.
  • 2 more comments
  • msavaso Mar 17, 2008
    Oven won't ignite or heat. Magic Chef made by Maytag model #6498VVVV
  • pete yuk Mar 21, 2008
    my amana acs3350as oven will not light on its own . the only way i can get it to light is bye turning on one of the stove burners at the same time as turning on the oven otherwise the oven will not work . when u turn on the oven alone there is no flame and no smell of gas . any help would be appreciated
  • rlm55 Apr 29, 2008
    I have cleaned the entire stove top (under hood), checked all the pipes connecting to the gas line for food, etc. and lined up everything properly. Burners still will not ignite except with a match. Oven and broiler always work. Burners will ignite without match if oven is on.
  • Ron Coons
    Ron Coons May 11, 2010
    OK, wanna try to post the actual problem??? include model and make if possible
  • 30 Answers
If it gas you need an Bake Ignitor, call your local service man
Posted on Mar 17, 2008
Oven not lighting
Replace the oven igniter. If it is a flat/rectangular shaped igniter use part# 5303935066:
Range Stove Oven Igniter 5303935066 .
If it is round, use part #:
Range Stove Oven Igniter 4342528
Jul 12, 2016 | Kitchen Ranges
Brown gas range auto ignition not working
If the problem is with all the burners then the igniter module may be defective. If this is happening only with some burners then the cable to the ignition point has become loose or is shorting with the body.
I am assuming the model number is correct but I am not finding any details for this 24 inch freestanding gas range. If the oven is electric and if it is running that means at least the electric power is reaching the unit.
Brown Stove Works INC
The oven parts are available here
Brown Range Stove Oven Parts
Sep 03, 2014 | Brown Stove Works TM110-3 Gas Kitchen...
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Gas oven won't turn on, stove top works fine.
check if the igniter is getting a 110 volt power if yes replace the igniter
Sep 05, 2011 | Kitchen Ranges
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Stove will ignite, oven will not ignite
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 04, 2010 | GE Profile 30" Self-Cleaning Freestanding...
Magic Chef freestanding gas oven/stove - oven won't ignite and heat, stove works fine.
most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Mar 17, 2008 | Kitchen Ranges
Kitchen Ranges Logo
206 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
