Question about Kitchen Ranges
Magic Chef freestanding gas oven/stove - oven won't ignite and heat, stove works fine.
  • msavaso Mar 17, 2008
    Model #6498VVVV. Igniter click starts
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Posted on Mar 17, 2008
  • Ron Coons
    Ron Coons Mar 17, 2008
    there are 4 possibilities for your problem ill go over all 4 just in case.. Can you see a pilot flame underneath??? does it grow larger when the temp is selected higher?? if not sounds like a bad thermostat. if the flame does grow larger, enough to extend out and hit a little sensor rod located at tip for the burner assy??? that little bulb/ sensor is connected to the safety valve, if its completely engulfed in flame and still does not open valve you need a new safety valve.*** you might have knocked the sensor bulb outta holder with something in the broil area, make sure its secures to front of burner ig niter straight and secure. lastly does it even spark to light???? one module controls all the sparking for the entire unit. so if you turn on oven andget no spark, try this;; turn on oven 200 degrees , now while watching the burner try lighting any of the top burners(turn to the light position where it clicks) did the oven light that way??? if so you have a bad spark switch for the oven control. if you still saw no spark you have a bad spark module
I have Magic Chef gas oven. Model CPR1100ADW. The pilot light don't light up nor does it come on. I don't smell gas coming from it. I can't figure what it is. Can you help me.
The oven probably has an igniter to light the pilot, and when not in use, shuts the gas off. Unplug the stove to replace the igniter. Enter your stove info and "how to replace oven igniter" on you tube for videos and detailed instructions.
Dec 14, 2017 | Magic Chef Kitchen Ranges
Our MAGIC CHEF gas range has a pilot light that comes on, the ignitor comes on, but the oven does not work heat. Any ideas would be appreciated.
First off, decide which you have, a pilot lite or an igniter coil. In electronic controlled units, when the oven won't light, as long as there's gas available, 98% of the time the igniter is bad, even though the old one may glow and seem to be very bright, it could have a small hairline crack in the ceramic, which would not allow the proper amount of electrical current to travel to the gas oven safety valve, which would then make it open and release the gas. A new igniter works almost every time.
Jul 03, 2011 | Magic Chef 31000 Gas Kitchen Range
Why won't my oven ignite? The stove top burners work fine, but I can't seem to get the oven to work. It get's warm, but I can't see that the gas is working.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 15, 2011 | Magic Chef CGR1110 Gas Kitchen Range
I have a magic chef gas stove witch has electric pilots.when i turn on oven it seems the electric pilot lights up but the burner doesn't come on.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Jan 06, 2011 | Magic Chef Ovens
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
I have an early 70's Magic Chef series VI oven/stove. The stove works fine. The oven takes about 30 minutes to light. When oven knob is turned pilot works fine. There is no gas odor before the oven lights.
My model is a UA119A-2W and I cannot find a place to light the oven pilot. Nor can I find a copy of the owner's manual anywhere online. Any suggestions would be appreciated.
Apr 05, 2010 | Magic Chef 31000 Gas Kitchen Range
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Ovens not lighting magic chef
Oven not Working or Oven not Heating
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
541 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
