Venta - Airwasher LW14 Humidifier
Problem for Venta - Airwasher LW14 Humidifier
Drum does not turn
By chungdh on Mar 17, 2008
My Venta humidifier is having a problem. The drum does not turn and consequently the humidity stays the same in my room. The fan unit still works. When I remove the lid and turn the drum manually, it works. But when I replace the lid and turn on the unit, the drum does NOT turn. After several days of seeing the humidity in my room stay unchanged despite the Venta unit running, I did some tests to see where the problem was. I concluded the drum was not turning because I marked the drum and ran the unit for awhile. When I opened up the lid to observe the drum, it was still showing the same mark (it had not turned at all).
Can you please tell me how to fix this problem?
Thank you.
Same Problem
Nov 01, 2008
-   I have the same problem. Used the water treatment as directed since buying it two years ago. Fan works, drum doesn't turn.-   dittbren
Nov 01, 2008
-   Same problem. I have used the water treatment since buying it two years ago. Drum does not turn. Seems like some units may be defective.-   Guest
Oct 16, 2008
-   Motor runs, fan turns, but drums do not turn. Have tried to clean [gently] the little fingers that engage the drums and turn them, but without success. I've suggested spraying the fingers with WD40, but my wife vetoed the idea, saying that only the Venta water treatment should be used. -   jrnwitmer
Best Solution
posted on Dec 26, 2008
Helpful)
hightor
Rank: Apprentice
Rating: 88%, 2 votes
The rubber coupling is slipping. You may have a problem with the gear case; you can get a new one by calling Venta at (888) 333 8218. But it's possible that the rubber coupling is simply not seated properly. Snap the gear box out and make sure the socket is clean. When you put it back make sure that the coupling post is fully inserted in the drive socket. Hope this works for you ... Venta will supply new parts promptly if you decide you need them.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 23, 2009
Not Rated)
Linda Banks
Rank: Master
Rating: 0%, 0 votes
I was having the same problem and all it was was a gaer box. There is a web site that has parts and an online tech support for Venta humidifiers www.ventahumidifiers.com
Was this helpful?
Yes
No
Popular Solutions for Venta - Airwasher LW14
Questions and Unsolved Problems for Venta - Airwasher LW14
Do you recommend Venta - Airwasher LW14 Humidifier?
Answer
Answer
water valve stays on all time 2001 model
Answer
how do I know if my Aprilaire Humidifier - Model 550 is working? I need a booklet
Answer
valve makes a loud clicking noise and activates over and over again
Answer
my model 600 aprilaire humidifier will draw water even when the fan on the furnace is not blowing.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta - Airwasher LW14...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2528
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
