I have installed a new color wheel. When I put everything back together It was great. Unfortunately the safety switch had broken and I tried taping it in an on position. That worked, but after getting the TV back into its location, it now has a dark translucent diagonal shadow across approximately half the screen. It almost looks like something is either obstructing part of the lens or light source. Do you have any suggestions?
it is possible that when you changed the color wheel you damaged the light tunnel. depending on the model number this may be a replaceable part.early model tunnels are easy to change with no tunnel alignment problems but later models the tunnel is easy to change but almost impossible to align
my samsung model# HLN617W the picture went to black and white and it's not clear.did the lamp go...
(More)(More)
my samsung model# HLN617W the picture went to black and white and it's not clear.did the lamp go bad or is it another ;problem?
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
model HLN617W dlp turns on then goes green screen then shuts off after 5 min. Bulb is new and color...
(More)(More)
model HLN617W dlp turns on then goes green screen then shuts off after 5 min. Bulb is new and color wheel too. what is it likely to cause this?
Posted. Thank You!
HLN617W all three lights in the front are on solid. The DLP light does not come on and I cannot...
(More)(More)
HLN617W all three lights in the front are on solid. The DLP light does not come on and I cannot turn the TV off unless I unplug it. I changed the light same results.
Posted. Thank You!
two top lights on the front of tv are on (not blinking) the bottom one is not lighting up. Is this a...
(More)(More)
two top lights on the front of tv are on (not blinking) the bottom one is not lighting up. Is this a bulb problem?
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
