Question about Toshiba Tecra 8100 Notebook
My A105 Toshiba Satelliet is stuck in hybernation and will not come back on
Yesterday I closed all programs and then shut down my computer. I came back later to do some more work and discovered the "yellow" light flashing as if the system was in hybernation. I presssed the power button as if to turn it on and the button turned blue as if it was going to work but the screen never came on. I pressed the blue button to turn it off and it turns "yellow" again as if it's hybernating. I tried unplugging, disconnecting etc................it's still doing the same thing............nothing will work.........not sure what else to do.
Signed,
About to toss it
    Guru:
  • 377 Answers
Hi dear
oke ...try to remove the battery from your notebook, try on with only adaptor
after normal you can put your battere again
thnks
cropp
Posted on Mar 17, 2008
Wifi cuts out after Standby mode - won't connect to preferred net
Try to reboot, and don't put it on standby anymore. Try putting in it in hybernation instead.
See if that helps. If it does not, post my a reply.
thanks
Apr 10, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 problems
Sounds like a program is not loading properly. You should try to load in Safe Mode, And see if it starts properly. If it does you then can do the diagnostics to find which program is trying to load and shuts machine down. You may also try starting in step by step and catch it right away. Depending on your version of Windows you are running you may be able to restore to a previous time when your machine worked right. Good Luck and have a good day.
Mar 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
Boots but to a blank screen just the pointer remains
Have you tried safe mode? You can access it by hitting F8 while the computer is booting up (I tend to press it at 1 second intervals, much faster and the computer gets annoyed :P) You'll get a menu that will let you pick safe mode.
If you can get at the desktop in safe mode then i would suggest shutting off all your start up programs (the list can be accessed by going to the start menu, selecting run, typing in "msconfig" and pressing enter). After those are shut off try rebooting back into normal mode and see if that works. If it does, then you know that a program starting up with the computer is causing the problem and just need to be singled out and removed.
Good luck :)
Dec 17, 2008 | Toshiba Satellite A105 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Problem with black screen
have you try to check your battery? try to put some colling fan to your laptop to avoid hybernation of your notebook..
Mar 26, 2008 | Computers & Internet
My Toshiba A105 went into hybernation and will not come back up.......................
unplug the laptop, remove the battery, wait 15seconds, put the battery back, plug it back in.
If it doesnt work after this.
Drop me a line and il give you more assitance.
Mar 17, 2008 | Toshiba Satellite A105 Notebook
Toshiba Tecra 8100 Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
