Question about Amana ALG443RAW Gas Dryer
Amana ALG443raw gas dryer
My dryer doesn't heat up as hot as it used to and a load now takes 2 - 3 hours to dry. Also, the automatic setting doesn't work (it stays set on less dry or more dry - where ever I set it initially). The timed sections seems to still work but it still has to go through the 70 minute cycle several times to dry the clothes. Thanks for your help!!!
  • Anonymous Mar 25, 2014
    I painted a paper covered tube art project and varnished it with pvc it stays tacky doesn't seem to want to dry. Help
    President:
  • Amana Master
  • 2,651 Answers
Not a problem with the unit, you have a clogged vent. its generating the heat your e not exhausting the heat properly ck behind the unit for kink, perhaps the outside exhaust hood has a screen thats clogged. dont know where its located but if feasible disconnect the dryer vent and try running a cycle . bet it runs a lot quicker... CLEAN YOUR VENT ITS A POTENTIAL FIRE HAZARD!!!!!
Posted on Mar 17, 2008
  • RSeegolam Apr 26, 2012
    You might be on to something. A few months ago I had HR-FUR came in and clean my vents. They pulled the roof vent flapto seat behind the stopper and the vent won't open thereafter. The heat backed up in the dryer and the house. After that the probleem started. I replaced the control board and it worked fine for about 6 months. Now it started again. . Possibly the dryer was pushed back and the flexible hose is crimped. Thanks I will try that - oening the vent and put a piece of wood in the back of the dryer to prevent it from going back that ar.
    Genius:
  • 3,587 Answers
Sounds like the thermostat is shot..do you fix this sort of thing yourself?
  • Patrick Michaels
    Patrick Michaels Mar 17, 2008
    other option, is that your heating element is rusted out
My gas dryer doesn't heat very well, if at all. Do I need to replace parts or are there ways do check and clean parts.
First i would clean the dryer vent. If the vent is clogged then the dryer cannot circulated the air inside the dryer. This will cause long dry times. If the dryer heats at first then doesnt heat anymore after about 10 min you probably need new coils
Jul 15, 2011 | Amana ALG443RAW Gas Dryer
Amana Dryer ALG443RAW little heat. It heated slightly and know there is no heat. It is also very noisy when drum is turning.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 11, 2010 | Amana ALG331RAW Gas Dryer
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
It ignites but does not heat hot enough to adequately dry clothes even though the gas is ignited. Doesn't appear to be hot enough. Amana ALG643RBW.
take the exsaust off the back of the dryer and run a load with it dettached and see if this makes a difference and let me know
Jun 21, 2009 | Amana ALG643RB Gas Dryer
Amana dryer model #LG4309W doesn't heat up like it used to
you need to get a vent cleaning the recommend that you get one evey 6 months with a gas dryer.
Dec 10, 2008 | Amana ALG443RAW Gas Dryer
It takes hours to dry small load
dud thermal sensor, the temperature is shuttimg off too low
locate, replace the thermal sensor just 'downwind' of the flame
Mar 26, 2008 | Amana NDG7800AW Gas Dryer
Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Mar 12, 2008 | Dryers
It takes 3 hours to dry one load
vent restiction look over the back of the drier and see if the vent is mashed folded etc then turn drier on go out side to where the hood is see how much air is comming out if very little find out whats blocking it
Dec 31, 2007 | Amana NDG7800AW Gas Dryer
Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Dec 05, 2007 | Amana ALG443RAW Gas Dryer
Amana ALG443RAW Gas Dryer Logo
183 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
