Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips 60PP9202 cables
On my Phillips 60PP9202, I have replaced the convergence ic's. It is chirping when powered on. There is a thin white cable on the same board as the convergence ic's that is crimped. It plugs into slot 1340 on the board and. Do you know the name of this cable or a part number for it?
    President:
  • 4,402 Answers
Nope sorry
Posted on Mar 17, 2008
Im looking for a projection alighment chip for 60pp9202/17f phillips
you will require two of the STK392-120 Convergence ICs and possibly the 6.8 ohm resistors. The Phillips DPTV305 - DPTV335 convergence repair kit available from www.tvrepairworld.com has the two ICs and the 12 resistors plus the CD with repair instructions.
Sep 25, 2011 | Philips 60PP9202 60" Rear Projection...
Can not get the colors to convergence
You will need to replace the 2 convergence ics and also check the 12 6.8 ohm resistors since they will usually blow when the ICs fail on a phillips. You can get the convergence repair kit for your phillips from www.tvrepairworld.com which contains the ICs, resistors heat sink paste and the CD with repair instructions.
Jul 10, 2011 | Philips 60PP9202 60" Rear Projection...
I have a phillips 60PP9202 60 the blue convergence going down doesnt work it goes so far and it stops like it reached its. limit
xlt1873,
Since you can move your beams but not far enough the convergence ICs are good. Your porblem is with the digital convergence box. You will need to replace it.
I have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which will help you complete the reapair.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 27, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60PP9202 60in. rear projectiov HDTV, but the red and blue colors are outlining the faces
you need to replace the convergence ic's you can get a convergence kit from.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.tvrepairkits.com/xcart/home.php?partner=larry
techman
Feb 18, 2010 | Philips 60PP9202 60" Rear Projection...
I phillips 60pp9202 red went out of focus so i replaced two Stk 392-120 with Stk 392-180 and two resistors, but now i have a bow effect please help
check resistors on convergence board for open ,check wiring and make sure cables were placed in right place then perform auto convergence
Jun 11, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Help my 60pp9202 for the holidays. Short on cash.
sounds like shorted convergance IC's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 10, 2007 | Philips 60PP9202 60" Rear Projection...
60PP9202 No Color
Bad chroma processor or related component....accordianman
Sep 25, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
