I have Adope Acrobat 8.1.2and can't print pdf. It comes up with unable to start print job. Is the printer available? I have tried everything from downloading it again to moving it to my documents etc. Can you help me out with this?
  • njjeff Mar 17, 2008
    IT IS A HP 5610 ALL IN ONE AND YES I CAN PRINT EVEERYTHING BUT PDF'S
  • J. Adam Morris
    J. Adam Morris May 11, 2010
    What model is your printer?
    Can you print with other applications like Word or IE?
    Problem Solver:
  • 11 Answers
Interesting. Well, I have two suggestions.
If you're using Acrobat Reader, try downloading Fox-it Reader, a free, lightweight alternative to Adobe's product. It's a fully functional, drop-in replacement. It's not exactly a fix, but a possible workaround.
The other option is to try reinstalling your printer drivers, which may have become corrupted somehow. You can download them from HP's support page here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=441125&lang=en&
Hope that helps.
Posted on Mar 17, 2008
I keep getting an error message when I try to save a file as a PDF. It tells me it is unable to initialize the PDF Printer driver.
Try starting adobe acrobat before trying to print/save. If screens come up wanting you to agree to a license agreement, you need to do so. A lot of times, this software gets installed, but never gets started, and therefore never gets the license agreed to! Once this is done, and acrobat is working properly, try to print/save.
If it does not work...
You might try to re-install adobe acrobat.
This can be done by going to control panel and then to add remove programs..
Select adobe acrobat and click remove.
After that, you can re-install using your acrobat disc. If you do not have an acrobat disc, you may find the software up at Adobe's website:
Adobe.com/acrobat
or
Adobe.com/acrobatreader
Once this is re-installed, you should be able to launch the print to file!
Feb 23, 2011 | Broderbund PrintMaster Platinum 16
I want to print pdf files but the mesage "unable to start print job. Is printer available?" apeares. i have adobe acrobat 8 . i can print this document with another computer with the same adobe...
go to start...
control panel...
printers and hardware (or something like that where your printer is listed.)
Double click on your printer and the document queue window opens
Now go to file, right click and check if the 'use printer offline' mode is checked. Uncheck that and you should be good to go.
Otherwise there could be a problem in the USB port of that computer. Try and connect the printer directly to USB and not through an extension.
Jul 24, 2010 | Adobe Computers & Internet
I have downloaded Adobe Acrobat reader 9, I have made adobe acrobat reader the associated default programme for pdf files and still I am unable to print a pdf file from the internet or e-mail without...
when you send a job to your printer from the internet it is basically the same as downloading the program first before it can be spooled. this is causing a time out problem with your printer.
Dec 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
I can't print pdf files from the internet, I have to "save as"1st
Sometimes the file name assigned to a pdf is not compatible with our printer's memory. For example, if the file name includes brackets [ ] or other punctuation, or is very long, the printer won't recognize it. One print job that stalls will hold up the entire print queue, so delete your job from the queue.
First, look at the file name displayed in the print server's list of print jobs. The same file name also appears in the top blue bar of your Acrobat pdf display. Are there brackets, per cent signs, or other punctuation marks in the file name?
Dec 28, 2009 | Microsoft Office Home and Student 2007...
Msg saying unable to start print job. is printer
Uninstall the Adobe PDF viewer and then reinstall it as the printer is respondingto other print commands,so its an issue with the s/w you are using.
Jun 11, 2009 | HP PSC 1410v All-in-One Printer
I cant get the Adobe Acrobat Pro 7.0 PDF Printer to work. It comes up with an warning 20225 code; setup was unable to create a new item.
I got 2 possible solutions:
Solution 1: Use a supported installation.
-- If you install Acrobat (Professional or Standard) on a 64-bit operating system, you may see this error. Install Acrobat on a 32-bit operating system.
-- If you install Acrobat to a shared network disk instead of a local hard disk, the Adobe PDF printer is not installed. Install Acrobat on a local hard disk.
-- If you install Acrobat to a directory with a path that contains extended ASCII or double-byte characters, English installations will display the error message. Install to a path that does not contain extended ASCII or double-byte characters.
Solution 2: Ensure that the Print Spooler process is running and set to Automatic, and then repair Acrobat.
1. Select Start > Settings > Control Panel.
2. Double-click Administrative Tools and then double-click Services.
3. Locate the service Print Spooler.
4. If the Startup Type is not Automatic, set it to Automatic:
a. Right-click the Print Spooler.
b. Choose Properties.
c. Choose the General tab.
d. Choose Automatic in the Startup Type menu.
e. Click OK.
5. If the Print Spooler service is not running, then start it.
a. Right-click the Print Spooler line.
b. Select Start from the menu.
6. Start Acrobat, and choose Help > Detect And Repair.
God Luck!!!!
Mar 12, 2009 | Computers & Internet
HP Deskjet F4180-no option to save as PDF
A simple solution to this problem is to scan to JPG as normal and then print the JPG to a PDF using one of the very good "print to PDF" utilities like the Cute PDF writer.
Good luck.
Aug 30, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Editing in adope file
u can easily edit all pdf files in adobe illustrator cs versions
Aug 26, 2008 | Adobe Acrobat 6.0 Professional for PC
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
