Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
GE profile dishwasher
All of a sudden,instead of showing normal time for settings, it shows "I hr" for all settings and does not start. or takes a very long time to start.
  • sherifred Mar 21, 2008
    My GE Profile 7800 will not start today, and has a "2 hr" time remaining reflected no matter what cycle I press. I checked to make sure there was nothing blocking anything inside, but dishwasher will not start.
I talked with a GE techy, and was told to either turn off the circuit breaker or unscrew the fuse for the power to the dishwasher, wait 45 seconds, then turn the power back on. GUESS WHAT? IT WORKED!!! try it.
Posted on Mar 21, 2008
SOURCE:
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
My GE Profile dishwasher has gone from 56 minutes to 70 minutes to 71 minutes to do a standard wash (checked a couple of times to be sure I had consistent settings). Suggestions as to what has changed.
That is normal. I had a GE Profile dishwasher at my house, and it what it is there is a sensor inside the dishwasher. It senses how many plates you have in your dishwasher and wash according to your size of dishes you have in there.
Apr 21, 2011 | Dishwashers
Screen frozen with 1 hr remaining
unplug it for a few minutes, see it that resets it.
Mar 02, 2010 | GE Dishwashers
I have a GE Profile Triton Dishwasher and it has worked fine for about 8 years. Suddenly it will not reset. The reset light blinks after reset but you can not choose a normal cycle afterwards. I shut of...
Hello, how are you?
It sounds like you have a stuck key on the keypad, preventing you to push any other key.
I've seen this problem many times in the past 4 years.
Good luck.
Ned
Sep 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Control panel showing count down number "999,888, 777, 666, ...."
You somehow got it in TEST/Maintenance mode. I think if you PRESS and HOLD Start for 15sec, it will go back to normal. If not, pull the plug and let sit for 1/2hr
Cheers!
Mar 26, 2009 | GE PDW9200N Built-in Dishwasher
C5 error on GE Profile dishwasher
C5 - Low Water Fill - This error usually indicates bad water inlet valve. Check for low water pressure to unit.
Dec 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE Profile built in dishwasher problem
Try cutting the breaker off for 5 min, This will reset the control.
Mar 14, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
300 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
