Question about Magellan eXplorist 500 GPS Receiver
Configure NAND on Start up
When I start mu Explorist 500 this is what I see on the screen< "Press ENTER to configure NAND. Press ESC to cancel." When I press ENTER I get a message telling me "Configureing NAND" then the screen goes blank. If I press ESC It goes directly to the blank screen. The darn thing worked fine yesterday. The only thing I did between then and now was charge the battery.
Any body have any ideas?
Oh yes what the heck is a NAND?
  • ppablop00 Sep 11, 2008
    Hola yo tengo el mismo problema y no se que hacer?
I finally wound up deleating the base map useing the Maintenance codes, which has now left me with another problem and that How do you rload the basemaps from Mapsend Lite?
Stewart
Posted on Mar 17, 2008
SOURCE:
My eXplorist XL is locked up
Error message at start-up reads: "Press ENTER to continue NAND, Press ESC to cancel". Either choice I seclect and the unit shuts-down.
"With you XL turned off press nav + power; then change the numbers in the box from 00 to 95 by using the joystick and then press the joystick itself; (ENTER), accepting what is proposed...
Either FORMAT or SCAN... LET IT RUN!
After turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. Your system will immediately start to re-set itself.
If necessary, in usb file transfer mode, reload the basemap in the directory background maps..."
The only difference is that I had to load my SD card in the unit for it to work during the FORMAT.
My unit is NOW re-booting back to normal!
Sep 02, 2008 | Magellan eXplorist XL GPS Receiver
Help Explorist 500 jammed (locked up) wont even turn off
To speed things up a bit with frozen Explorists, you can undo the battery cover and pull out the battery then replace and start again. I have had to do this many times.
Jun 10, 2008 | Magellan eXplorist 500 GPS Receiver
NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Jun 06, 2008 | Magellan eXplorist 500 GPS Receiver
Error Message? "Press ENTER to configue NAND Press ESC to cancel"
With you 500 turned off press nav + power; then change the numbers 00 in 95 by using the joystick and and then press the joystick itself; accept what proposed.
after turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. if necessary, in usb file transfer mode, reload the basemap in the directory background maps
May 24, 2008 | Magellan eXplorist 500 GPS Receiver
Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Feb 24, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500
Dec 28, 2007 | Magellan eXplorist 500 GPS Receiver
I can't get the map on the screen of my eXplorist 500
no solution exists.
.ecw files contain raster maps not compatible with GPSRs.
only .imi files compatible with eXplorists can be loaded
Nov 05, 2007 | Magellan eXplorist 500 GPS Receiver
Explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
Explorist 300 problem
Try to reseting to the factory defaults: Press menu - choose preferences - press enter choose reset default - press enter choose all - yes - press enter Good luck!
Dec 31, 2005 | Magellan eXplorist 300 GPS Receiver
Magellan eXplorist 500 GPS Receiver Logo
513 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
