Toshiba satellite will not start
Hi, thanks for your help yesterday your solution of removing the battery and trying with the power adaptor worked gine. Does this mean I need a new battery pack? The battery pack is 6600mAh and when showing 100% charge indicates just under 2 hours running time on battery power, thanks again for your help
    Genius:
  • 3,587 Answers
Yes..that's precisely what's needed..
Posted on Mar 16, 2008
  • Patrick Michaels
    Patrick Michaels Mar 16, 2008
    you might consider running the battery up and down a few times, and see if it will hold any charge, but do this when there's nothing important on the machine.
    also, go to control panel, power settings(behind display on xp) and set the alarms for higher ratings(25 and 8 are usual)
I have a Toshiba L35 Satellite S2174. I lost my power adaptor so started to use a HP adaptor of same 19 V , but Different Current 3.16A. I dont have the current rating of my original charger. The...
Hi Arsalan
To answer your question Its "yes". wrong power/ampere rating can shorten the battery life. I recommend that once you replace the battery include the AC adapter.Thanks
Feb 20, 2011 | Toshiba Satellite L35-S2174...
Hi i can't switch on my girlfriends Toshiba
Hi, first things i would try is to switch it off all togther, remove the battery and power lead and leave it sit for 10 - 20 minutes to let any residual power drain from it.
once you have done this just plug the power supply back in without the battery and try to switch it on, if it works ok, plug the battery in and see what happens if it fails to start up after this its most likely the battery is at fault.
if it will not start up just on the power adaptor then there is likely to be a hardware fault with the laptop itself that may need someone with some computer repair experience to fix for you.
hope this help.s
Jul 18, 2010 | Toshiba Satellite L300D-ST3501 Notebook
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
Toshiba Satellite A105 laptop won't boot up?
hi,
Please try the following steps
1.remove the battery and press the power button till on eminute.
2.plug in the power adaptor and check whether it is working(without battery)?
3.Refix thebattery and check.
If then also it is not working either the RAM is faulty or needs to be refixed so please oonce refix the RAM.
Thanks
Jul 06, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
TOSHIBA SATELLITE NOT STARTING.
mine does the same thing and is new. you should be fine with what you have for a while, unless you just want to replace the battery, the battery goes bad after a few years, thats what I have heard anyway.
Mar 16, 2008 | Computers & Internet
Toshiba won't start
Hi, what happens when you push the button? Lights, sounds from inside the laptop, anything flash on the screen?
Sep 27, 2007 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
