Sony NWZ-E438F Digital Media Player Logo
Posted on Apr 05, 2010
Mp3 8GB NWZ-E343/E344/E345
THE SCREEN DISPLAYS ON HOLD
HOW DO I CANCEL IT?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
384
Points
How do I download music from CDs as well as from the network?
1helpful
My nwz E344 is stuck on connected usb. It will no go off even when disconnected to my computer. Don't know what to do.Screen will not go off.
If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object
NOTE: This may delete all content from the device. I am not responsible for any data loss.
1helpful
2answers
NWZ-E344 buttons won't work, stuck on home screen
try kissing it and tell it you will not replace it with an ipod touch
7helpful
3answers
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Is is possible to put a photo as a background or as screensaver?
There is no option in the NWZ-E344 Walkman Player to set an image as Screensaver. You can either set a Blank Screen as Screen saver or the Clock.You can press and hold the BACK/HOME button, select Settings-->Common Settings-->ScreenSaver-->Type-->Desivered type(Clock/Blank).
Thanks for using FixYa
1helpful
What keys need to press to cancel hold function?
Sony NWZ-E344 has hold switch on right side, slid hold switch to cancel hold function.
Let me know if model number of mp3 player is different to provide you revised info.
Thanks.
How do i add photos to my nwz-e344
Connect the Sony Walkman NWZ-E344 (8 GB) Digital Media player to your computer using the device's USB sync cable. Wait until your computer detects the MP3 player.
Click the "Start" icon in the taskbar. Click "My Computer."
Double-click "Removable Disk." This will open the root storage directory of your MP3 player, which is where all its files are stored. Locate the "Photos" folder inside this directory.
Drag-and-drop pictures from your computer into the Sony Walkman NWZ-E344 (8 GB) Digital Media player Photos folder: Click on a picture file and hold down the mouse button while moving the file to the Photos folder, then release the mouse button to copy the picture to the folder. You can now view these pictures on your Sony Walkman NWZ-E344 (8 GB) Digital Media player.
If your Sony Walkman NWZ-E344 (8 GB) Digital Media player does not support photo viewing, you can still add pictures to the device. Drag-and-drop the pictures anywhere within the root storage directory. You can transfer the pictures to another computer or any USB-compatible device.
Good luck.
Sony NWZ-E344 showing a blank white screen. Help needed
Please reset the player and the fault will be resolved.Check for the reset button hole, depress and hold to reset.
Now connect to the PC, make a good scan and delete off bad files.
2helpful
2answers
WMV. Isn't supported by mp3.
dear aryathe los.let me help you ,
First ,let me see have a look at the supported format of walkman NWZ-E344:
MP3 • WMA • AAC -Audio Format
MPEG-1 - Video Format
If you want to knwo more review about this mp3 player ,please click here http://www.dealtime.com/xPO-Sony-Walkman-NWZ-E344-8-GB
So i think maybe you need to convert the wmv to MPEG-1 and then put it to your walkman player.
by the way ,if you found you can't find the video when you are using software,maybe it includes DRM-Protection.just guess.
Anyhow ,try the method as you know,i think you will found the right way ..for the software ,personally ,i used this video converter,it can convert wmv to mpeg-1 and it can also remove drm from wmv ...
6helpful
2answers
My nwz e345 is stuck on every music has it moment screen then it freeze. then when i plug it to the usb it say device driver software was not successfully installed
Hey, I had the same problem, I found the solution!
First, reset your Walkman via a pointy object and the hole in the back. Then, replace the USB cord you use to charge and add music (it's a quite common cord for cameras and can be store bought).
This solved it for me!
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
