I rebooted my Acer Aspire 3680-2682 laptop, and I now don't hve any of the Acer empowering Utilities. My laptop needs go back to factory default settings. Also my product key is torn and I can't read it. Help
*******All of your data WILL be lost during this process so back everything up first**********
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
OR
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
OR
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
***This will erase all your unsaved data!***
Or
Or
2. Select Repair.
aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
Hello
1. Restore your unit back to factory default via boot up on the ACER screen, hold down ALT and tap F10.
2. Select "Restore system to factory default".
3. Enter your Empowering Technology password and away you go.
If that doesn't work, your unit was shipped with recovery cd's
Hope this helps
try pressing just f10 and also try f8 and see if you get a recovery option there.
if the windows works on the computer you should be able to restore it to defaults from acer empowering utilities.
You will probably have to buy the Recovery CD from Acer. You should be able to do so using your serial number as proof of ownership. This will not work if you have a system (BIOS) password, and booting from the optical drive has been prevented.
I assume from the question that you want to restore your computer to factory default - like the day you bought it. Warning - this process will wipe out all you data unless you back it up to an external drive or DVD.
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of selecting Restore System to Factory Default.
If windows is not working but the system boots - Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
