Question about Kitchen Ranges
Looking for a button for an older, 10-15 years, Amana drop-in range. It is a push button switch but we just need the button. It's all black. I searched all sites(20-25) that I found. Any help would be helpful. She is visiting so I don't have the model number. Any suggestions? Thanks, Jeff
  • Ron Coons
    Ron Coons May 11, 2010
    a push button switch ??? perhaps a "rocker switch" to turn light on/off it "rocks"back and forth. up=on and down=off??? that the switch in question??? if not nad you do need apush button switch what is it's function??? and is it an electric or gas oven(itll help narrow the field of looking
It is in her home that she is selling, so she needs all buttons present. I got a 'appliance parts' order number from Home Depot. Hopefully that will work for her, as she has returned home. Thanks for your help everyone!
Posted on Mar 18, 2008
  • 30 Answers
Electronic control Button and might still have the foam backing, take the button from an other function, timer etc...
Posted on Mar 17, 2008
Where is the starting capacitor for a amana gas dryer
Dryer motors do not require start capacitors. Their is multiple windings in the motor and a centrifugal switch. When the start button is pushed all of them windings are on and when the motor gets up to speed start winding drops out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 31, 2016 | Amana Dryers
P5H code on an amana oven
This is actually the 'PSH' error code which stands for 'Push To Start'. If you do not press the start button within five seconds of a command that will display telling you, that you forgot to PUSH the Start button. If it is randomly showing up by itself you have a defective touch-pad
Oct 21, 2016 | Amana Kitchen Ranges
What does p5h code on an amana oven
The oven door is locked after pushing clean button.
Flip the breaker going to the oven and it will release.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
I dropped a jar on the ceramic cooktop now the hot surface light will not go off
Each element contains a sensor that activates an attached switch to the hot indicator light. The shock of the dropping jar may have damaged the switch.The associated element will have to be replaced.
Mar 06, 2012 | Amana ACF4265AS Electric Kitchen Range
I have to manually get drum turning...
Yes, there is a "startup" switch. It's the button you push on the panel (but I'm sure you know about that).
This switch energizes the start winding in the motor -- when the motor gets up to speed, a centrifugal switch in the motor disconnects the power from the start winding and switches to the run winding.
Either the start winding is not getting power or the winding is bad. If "no power" is the problem, it could be the button on the panel or a loose/dirty connection between there and the start winding. Lot of possibilities which need to be explored.
But if you know about pushing the safety switch on the door and spinning the drum by hand to get the motor started, you can probably fix this.
May 04, 2009 | Amana NDE2330AY Electric Dryer
Amana range
Hi j grangeruth,
Happy to help you!
If it is 10 years older or more, I would not recommend investing a lot of money into repair!
I think that this problem will be solved only by service!
Try these guys first!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Aug 24, 2008 | Amana ARDS802 Electric Kitchen Range
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Nov 25, 2007 | GE JGB916SEKSS stainless steel Gas Kitchen...
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
