Question about Kenmore 16225 Grill
Kenmore Master Flame Grill
I just moved into a new home and the previous owner left a Kenmore Flame Master gas grill hooked up on the deck. I took a quick look at it and am not able to get the grill to ignite.
  • Melissa Behar Apr 09, 2008
    There isn't a shutoff valve, it's possible the grill may not have worked for a while and the previous owner just didn't tell me about it. I guess at worst I can use it as a charcoal grill...
  • 36 Answers
Burner will not light:
Here is a couple things you can check:
1. Gas injector not insert in venturi tube.
2. Clogged gas injector
3. Obstruction in gas line.
4.Spider webs in venturi tubes.
5. Misalignment Of collector box and burner.
6.Dead Battery.
7.Check hose to make sure it is not kinked
8.Check Hose to make sure it wasn't chewed by squirrles
9. If it is LP gas, Could be out of gas.
Other Issues:
Could be the way the grill was turned on and off, that also can be an issues. In your manual it will tell you how to do it proper, this could make it not light or have a low flame. If there is not hing in your manual, I will be happy to assist you.
Fireplace-Girl
Posted on Apr 29, 2008
  • 32 Answers
CHECK TO SEE IF THERE IS A SHUT- OFF VALVE IN THE LINE
Posted on Apr 08, 2008
SOURCE:
Kenmore elite 5 burner grill manual
Kenmore Gas Grills Manual - Sears
https://www.sears.com/search=kenmore%20gas%20grills%20manual Items 1 - 37 of 37 - Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized ... Star Manufacturing Star - 848MA - Ultra-Max® 48 in Manual Gas Griddle.
Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized Rotisserie Kit
https://www.kenmore.com/.../kenmore-elite-kenmore-elite-5-burner-stainless-steel-gas... The Kenmore Elite 5-Burner with Rotisserie Kit: A Reliable Cookout Staple Play host to the perfect outdoors party with ... Play host to the perfect outdoors party with your Kenmore dual fuel gas grill. ... Assembly, Minimal Assembly Required ...
[PDF]Owner's Manual - The Grill Services Corporation
www.grillservices.com/manual-downloads/720-0286.pdf Kenmore Elite Warranty ... Burners: 5 Years. Flame Tamers: 3 Years. Cast Iron Cooking Grids: 3 Years ... grill. The gas regulator assembly supplied with your gas.
Kenmore elite 5 burner grill manual Google Search
Jul 28, 2018 | Kenmore Grilling
I just purchased a pre-assembled E-310 Weber gas grill from Home Depot. Upon Start up I noticed the flame is very high on each burner (three to 5 inches above the deflectors on high). Also, I notice n
Hey Anon..
WOA...compressed propane is not something to mess around with..I would go back to the Home Depot and talk to the store manager,,(take your receipt and all other paper work for proof), ask him who to see about your issue.. tell him you are afraid to use your NEW grill.(Start at the top!).. you spent good $$$$ and you deserve an answer..or a new grill..
Sep 11, 2017 | Weber Genesis E-310 Gas Grill
Side burner lights but not main burner on gas grill
If you smell gas, don't attempt to light the burner. Instead, turn the gas off and inspect the fuel tank, lines and burners once the smell of has has cleared. Always grill where you have adequate ventilation and perform all repairs only after the grill has fully cooled from use.
home lights
Jun 07, 2012 | Char-Broil CharBroil Master Flame Gas...
I have a Char-Broil Grill that I bought at Home Depot. I tried to use it tonight, and I couldn't get a strong flame. I had put in a new propane tank, and this was the first time I used it. What would you...
The new tanks have a safety feature, if the connector is cracked and there is low pressure it will shut off the gas flow from the tank.
Check the connector at the tank, I had a cracked plastic one.
Aug 13, 2010 | Char-Broil CharBroil Master Flame Gas...
Need advice and owner manual for Kenmore grill
Many Owner's Manual can be found online. Go to the Home page of Manage My Home and hold your mouse over the square labeled HOME in the upper left of the page. A drop-down menu will appear, choose the option Products and manuals and then enter the model information and follow the steps.If the manual is not available there, you might need to order a replacement hardcopy through your Sears Store or online through Sears. To find a parts diagram or list for your model online, go to www.Sears.com and select PARTS or go directly to www3.Sears.com
Jul 15, 2009 | Kenmore Grilling
Yellow flame from all carryover tubes. This grill is brand new
if the unit is running on natural gas, this is not unusual. if running off propane tank something is wrong with the regulator
Jul 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Flame Shooting out the front
You clearly have a gas leak. Inspect the suspect area for loose connections like the gas delivery pipe to the burner assembly. Try to reconnect them. If there is a hole in it you can use some muffler repair adhesive but I would just get a new part. Often the company will send you free parts as a good gesture to assure encourage repeat business. Check out the links below. The second one offers free shipping.
www.charbroil.com/CharBroilWarranty
www.clagrills.com/grillparts/charbroil/charbroil-grill-parts-home.htm
Jun 20, 2009 | Char-Broil CharBroil Master Flame Gas...
I have a Kenmore natural gas grill, model # 141-17227. I need the woners manual. The side burner will light but very low flame, cannot get the grill to light.
owners manual can be gotten through the internet- Sears.com find parts,type in model# of item, select manual sounds like valves are clogged- propaine and natural gasses are dirty gasses-no filter, it comes up out of ground,through dirty pipes, all the way to peoples homes- and thats why they have to replace valves on hot water tanks/furnuces........
Jun 19, 2009 | Kenmore 505 sq. in. Cooking Area Gas Grill...
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Kenmore 16225 Grill Logo
2,001 people viewed this question
Top Kenmore Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
