Question about Sanyo DS24205 24" TV
Okay also could i go to an electrican and get it fixed? and how much would it run me?
  • 373 Answers
I would not recommend an electrician because they do no soldering but an electronics savy person with experience
Posted on Mar 16, 2008
SOURCE:
I need to take out the main fuse case in engine bay . how do I get to all the connections underneath
Take it to an Auto Electrican and get them to fix it if you are unable to do it without help as you mat blow the computer
Apr 09, 2017 | Cars & Trucks
Tip
I was able to fix my moms rca using these instructions. She is on a very limited...
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Jan 10, 2009 | RCA R52WH73 Projection Television
Hi, I have a Fisher and Paykel Thyme Stove and the two big elements wont turn down, Whats wrong and can it be fixed cheap?
this is a common problem ,the switchs that turn on the elements are called thermostats,and they are faulty, an easy repair by any electrican
Sep 26, 2012 | Fisher and Paykel Ovens
Red lightining sign on dash grand 2006 grand cherokee jeep
Your alternator is not charging, thats fine when the motor isn't running but if it is running you are on borrowed time and it won't be shortly. If you need to drive some distance to reach an auto electrican charge the battery up first and use the minimum number of electrical accessories possible while you are driving there.
Jun 02, 2012 | 2006 Jeep Grand Cherokee
I keep melting fuses for my blower in my heater?
You have a serious electrical fault in your blower/heater. The fuse is protecting your wiring and prevents overheating/burnout.
Do not install a higher rating fuse as you can cause a fire.
You need to get an auto electrican to fix the short/fault.
Nov 25, 2011 | 2000 Chrysler Concorde
20 year old Rheem 90 plus 120k btu furnace blower runs contantly. Furnace and AC work fine (start and stop according to thermostat setting). What is problem? How fix?
Check to see if your unit has a heat sequencer. This is usually the problem with most furnaces. If it is bad, it will make the fan blower run all of the time. If you are not a electrican, you may want to get a electricin to look at it.
Dec 01, 2010 | Heating & Cooling
Kenmore dryer
first dryer should be on circuit by itself..if dryers runs ok for a while before tripping breaker call electrican to change breaker..change it not ck it ..too many times had electricans tell cust breaker ckd ok but after explaining to cust a breaker can not be ck without load they had breaker changed and solved problem ..not just old breaker but even new ones can cause problems..if breaker kicks as soon as dryer is turned on ck wiring at connection where ac is connected very seldom does any other issues with dryer cause immediate tripping of breaker
Sep 16, 2008 | Kenmore 63012 Electric Dryer
Sanyo DS24205 24" TV Logo
22 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
