Question about Kenwood DDX-6019 Car DVD Player
Kenwood ddx6019 my player works, all the buttons are functional but when on the screen does not light up, with a light you can see the touch buttons on the screen but its dark, how can this be repaired?
Aka your not helping these people god, you guys **** at life. ok heres the problem with kenwoods.... they have **** pardon my french.... ribbon cables that attach to the faceplate of the unit. odds of your faceplates backlight just mysteriously going out 1:50 odds of the ribbon cable breaking 1:5..... catch my drift. you can buy a replacement cable online for cheap so that could be your fix. now you will need to repair the unit either yourself or by a professional. but dont listen to these assholes cause its not that hard. but the consequences if you do are tragic. either way this part when bought will mst likely be cheaper than what the repair guy charges so you can take that route as well. i have had several ribbons from kenwood break on me in over a span of 10 years so wouldnt be suprised
Posted on Apr 20, 2008
  • orlandocato4 Apr 18, 2011
    Hi I have been trying to source a ribbon for my kenwood ddx6019 but can't find any online can u give me a site or source plzzzzzzz thanks
  • 934 Answers
The back lighting needs to be replaced - - shop only kind of repair don't attempt it yourself or I can just about assure you that you'll turn it to unrepairable garbage...
Bill
Posted on Apr 01, 2008
  • cartoys001 May 17, 2011
    Hi i change the sw assy and the lcd in my ddx-6019 but the sceen is no turn on more the touch work but the scree no. and since I do not know what happened, someone could help me
SOURCE:
How to reset om a kenwood ddx812
TO MASTER THE KENWOOD DDX6019 JUST POWER THE DEVICE OFF PRESS AND HOLD THE (RESET BUTTON) RIGHT NEXT TO THE (ATT BUTTON) WHILE HOLDING THE RESET BUTTON THE (ATT AND THE SRC BUTTON) NOW LET GO OF THE RESET BUTTON AND THEN THE OTHER TWO AND YOUR IN JUST
Mar 05, 2011 | Kenwood DDX812 Car DVD Player
I have a Kenwood ddx6019 with XM satellite radio. recently, I entered a manual channel change and lost all reception. A banner reads LOADING LOADING across the bottom of the screen. Any ideas on how to...
I have a Kenwood ddx6019 with XM satellite radio and sirius. i want to know how do i turn on the xm so i can get live traffic update and my garmin gps unit and weather. and were to i find the mx radio id for xm. i found it for sirius
Nov 01, 2010 | Kenwood DDX-6019 Car DVD Player
Cracked front screen
go to pacparts.com, they should be able to assist you.
Nov 11, 2009 | Kenwood DDX-6019 Car DVD Player
I need a new screen for me ddx6019. Do you know
crutchfield.com maybe they carry alot of car audio and home audio equipment
Nov 02, 2009 | Kenwood DDX-6019 Car DVD Player
Red light next to att
Did you ever find out what was wrong with it? Mine just did the same thing!!!!
Nov 01, 2009 | Kenwood DDX-6019 Car DVD Player
My kenwood ddx6019 wont turn on, but it will eject cd's and has a blinking red light next to the att button
did ya sdo it self cuz if soo you probly forgot to hook up the ignition wire because cds will eject while car is off check for power at ignitiion wire the red one coming from deck harness and then get back to me
Jun 14, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
JUST INSTALLED A KENWOOD DDX6019 WITH GPS FUNCTION / WHEN DRIVING THE TUNER SWAPS ERRATICALLY BETWEEN CALL(BLUETOOTH) AND TUNER WHENEVER i PRESS MY BREAK. REASON? SOLUTION? THANKS.
You might have your brown (mute) wire shorting out (grounding itself) near your brake pedal. Locate the brown wire from the rear and make sure that it completely taped making sure that it does not touch anything metal.
Feb 22, 2009 | Kenwood DDX-6019 Car DVD Player
Kenwood kvt-717 DVD..code
Have Kenwood KVT-717DVT.
It will uncurl and open screen and show only one screen. It's on "standby". The one screen shows the touch buttons "Audio", "Set Up" and "SRC". These touch button will not perform any functions.
I changed Motorhome's house batteries and this is the problem that occured.
Need the backup camera. Any solutions?
Oct 27, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood ddx6019
the double din kit was restricting it from opening properly, once i removed it from the kit it worked properly. i had to modify the kit for it to work properly!
May 25, 2008 | Kenwood DDX-6019 Car DVD Player
Kenwood DDX-6019 Car DVD Player Logo
440 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
