Question about Whirlpool Duet GHW9150P Front Load Washer
F21 can you please help me i have an f 21 error on a whirlpool washing machine. It is brand new?
    President:
  • Whirlpool Master
  • 2,651 Answers
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit
(CCU).
unit BRAND new id look into a wire off , 1year warr. id call them so as not to void any warr.
Posted on Mar 16, 2008
My washer whirlpool duet steam has a code of F 21 what does that mean
The Whirlpool washer error code F21 means the washing machine has a "water draining issue", meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out
Mar 30, 2018 | Whirlpool Washing Machines
My washer has the code F 21 can you tell me what the problem might be??
I'd check owner's manual, or Mfg web site for your model.
Feb 10, 2018 | Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Getting an error message on my Whirlpool duet washer - F21
F 21 means slow drain remove lower kick plate couples screws at bottom//you will see the drain pump there is a clean out at the front of pump/ turn that out counter clock wise that is a coin collector but many other objects get in it to/ remove items and reverse to put unit back together....
If I helped you please vote If you need more help please ask good luck
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front loading whirlpool stopped part way through wash with a F 21 error message. Please advise. Thanks; Kelly
Hi Kelly,
Thanks for using FixYa. Error F21 means long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Washing Machines
F21 code flashes
Lets see what an F-21 is shall we? F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.3a5b94a.jpgb4a897e.jpg55f108d.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Jul 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F-21 error
no f21 code but there is an F2 which is long drain remove the lint filter behind the bottom panel and check for a blockage first
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
