just to exclude anything faulty, start with the flash on the camera and check if it works. Also check the camera settings. On your Nikon you can chose flash off. Don't do that. If you get the flash working on the camera then you starts with the extension cord and it still should flash in the same conditions.
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
for the venerable 283?.... http://www.hiviz.com/activities/guidebook/sensor.pdf didnt find a manual online yet.... such a simple elegant reliable flash though ..should be no mystery to figure out without a manual...good luck
To test everything except the camera, just short the contacts on the Wein protector. If the flash fires, the problem is in your camera, and maybe the protector did not do its job as good as expected.
I need the cord to fire my Vivitar 283 off my Nikon d70s
