Question about Dishwashers
I have a Dishlex Glendale Deluxe and need a new seal for the bottom of the door. I cannot find what model number it is to source the part. Do you know what the part no. or model no. would be?
I have a Dishlex Glendale dishwasher and the model no is 10014380092 if that helps you.
Posted on Mar 03, 2009
Dishlex dx 403
The seal at the bottom of the door is a splash seal only. The only seal that does the real work is the big thick one around the sides and top.
That said, you can buy them from your electrolux parts shop.
If in Aus you call 131350 for the closest one.
It is easy to fix yourself, just unscrew the little screws around the inner edge of the door to remove the front panel. Do this while door is still on, you do not remove the whole door.
Also, be careful not to cut yourself. The inner and outer panel edges are extremely sharp.
Jan 19, 2014 | Dishwashers
Where can i get the Dishlex ranghood filters that more than 20 years old ?
The following Australian site carries Dishlex parts. You will need to know the model number of your rangehood or the size of the filter. If you know the model number simply do a more specific search to narrow your choices.
http://spares.alliedappliance.com.au/search.php?match=&keyword_list=Dishlex+rangehood+filter
Feb 15, 2011 | Microwave Ovens
My Dishlex Global 450 leaks, I have narrowed it down to the door seal and have replaced this. It appears to overfill during it's operation BUT not evry time? Sometimes it soaks the floor other times no...
Mine did the same thing. I cleaned the door seals, mostly the bottom one which collected a lot of grime & didn't provide a solid seal.
Hope this helps.
Jan 15, 2011 | Dishwashers
Water leaking from foam strip on the bottom of door
Be sure the seal around the door is clean and in position. If it is an older dishwasher then the door seal my need to be replaced. door seals can ordered on line if you know the make/model numbers of the unit.
Dec 17, 2010 | Dishwashers
How do i switch on the volcan dishlex 100s dishwasher
Hi just read your posting.Do you mean Vulcan Dishlex 100s?Have you got 1 big timer knob on the front right and 1 small knob to the left of the big timer knob?Or have you only 1 big timer knob?Please reply with additional information and I can help you solve this problem.
Jul 23, 2010 | Dishwashers
Water is pouring out of the bottom part of the washer door.
If your Whirlpool FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 10, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Seal on front door is torn
If your FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
repairclinic.com
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 04, 2010 | Kenmore Front Load Washer
Frigidaire dishwashers FDB2810LDC0 bottom of door leaking where do I find a new seal?
You can obtain a new seal through an appliance parts store. You will need the make and model number of your dishwasher to get the correct seal.
Oct 03, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Dishwasher door leaks heavily. this is a new problem today. The leak is from the lower right corner of the door.
It could need a good cleaning. Residue from soap and food tend to build up in that area all along the bottom of the door and seal. The other issue could be the seal itself, check the rubber seal at the bottom of the door and make sure it is not torn or damaged.
Unless the water level is getting to high, it should be one of these two.
Let me know. If you can provide me with the model number, I might be able to get a little closer.
Regards,
Aug 23, 2009 | Dishwashers
Dishwashers Logo
573 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
