Question about Nikon N55 35mm Film Camera
N55 Shutter Problem
Hi. I am having problems with the last few rolls of film that was developed from my N55 NIkon Camera. NO Pictures developed. I believe it is the shutter because when I open the back of the camera, (where you load the film) the black stips look like I may of stuck my finger in when loading a roll of film. How can I straighten this out without having to send it away for months. I am getting married in May and need to get it fixed ASAP
Thanks for your help
  • Tony Parsons
    Tony Parsons Jun 11, 2017
    Relax, May is eleven months away. Replacement may be a cheaper option than repair, especially as the camera is now nearing ten years old.
    New Friend:
  • 4 Answers
If the shutter blades get bent they are hard to straighten out. Better to find a local repairman or you could do more damage to the shutter. Sorry to be the bearer of bad news.
Posted on Sep 17, 2017
  • Greg Shape Sep 17, 2017
    If you bent the shutter blades and try to straighten them you could cause more damage. Try to find a local repairman. Sorry to be bearer of bad news.
Gryfox
  • 216 Answers
SOURCE: Camera turns off
Open the file door and check to see if the shutter blades look uneven, like they might have been pushed out of track. Sometimes it's simple to re-track them - other times it'll have to go to a repair shop. Another cause is the film motor wears out and has to be replaced - a job for the repair shop.
Posted on Nov 19, 2006
SOURCE: Film advance inoperative
check the polarities of the battery.
Posted on Apr 02, 2008
cammedic
  • 667 Answers
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Posted on Apr 27, 2008
cammedic
  • 667 Answers
SOURCE: Canon AE1 Shutter Problem
It could be a simple issue with the shutter magnets, or something more severe with the electronics. What does the meter needle do when you push the shutter release down? With the speed dial set at 1/125 or higher and no lens, the needle should move fairly high. If it pegs to the bottom right away, that is a bad sign.
You can check the magnets from the bottom with the cover removed. (2 screws) You can release the mechanicals of the shutter by pushing the silver lever arm (located next to the plastic shield around the magnet on the rewind side of the camera) toward the front of the camera. Be mindful of the spring attached
Posted on Oct 02, 2008
Gryfox
  • 216 Answers
SOURCE: my nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Posted on Jan 03, 2009
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
2 rolls out of a 3-pack ruined.
I would suggest you buy an off-brand roll of 12 or 24 exposures. Run it through the camera taking snaps of anything -- but make sure you vary the lighting, ISO, shutter speed, aperture, etc. as you snap the pics. Don't worry too much about composition. This roll is a quick test, NOT for photos to keep.
Have the film developed and then follow-up with comments on the results. I'll gladly assist you further at that time.
Char1ieJ
Nov 11, 2008 | Nikon N65 35mm SLR Camera
Film advance
no thers no more advanses but you can get them doveloped if there a surtin level
Oct 20, 2008 | Nikon N55 35mm Film Camera
Nikon n55 manual mode f.stop and shutter speed controles
There is a downloadable PDF format Nikon N55 manual from http://nikoneurope-en.custhelp.com/cgi-b...  . Thanks to Ands for this tip.
Sep 25, 2008 | Nikon N55 35mm SLR Camera
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Apr 28, 2008 | Nikon N55 35mm SLR Camera
FILM REVERSAL
does anybody know a freakin solution????
Jan 09, 2008 | Nikon N55 35mm SLR Camera
Film doesn't develop
check your camer without film:
1). open the back, use different combinations of film speeds, shutter speeds and apartures. if you can see light coming in from the lens, no matter how little light and how fast.
2). check that film advances or not. if you camera detects film and loads automatically, insert any expired film cassette, or badly developed film and roll it back into cassette.
3). send it for service if either one or both gives you an answer of "N".
Jan 07, 2008 | Nikon N55 35mm SLR Camera
Developing pictures
depending on the type of film you are using and where you are taking it could be the problem. if you are using professional film and taking it to a pharmacy to get developed, the chemicals used at these places will erase the images off the film and appear as if the film is blank.
Nov 11, 2007 | Nikon N75 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
Camera Rewinds New Roll of Film
Check the camera and the manual to see if there is a control to override the auto rewind; it may be set to rewind. Other than that, check Mikon's website for support info.
Jun 16, 2007 | Nikon N55 35mm SLR Camera
Nikon N55 35mm Film Camera Logo
1,116 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
