Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Silver Box
We have the same promblem as the article you responded to in the RCA tv. My question to you is how do we remove the Silver Box from the TV? Do we pull it out or unscrew it? We are afraid to break something.
Thanks.
MCB
    Genius:
  • 1,030 Answers
Silver Box? please explain your problem...for d52w20
Posted on Mar 27, 2008
I use a RCA remote to programe my cable box but my samsung tv get programe instead of the cable box.and now my samsung tv goes on and off. What's wrong?
The TV and the cable box are responding to the same code. You likely will have to find different codes for one or the other.
Jan 17, 2016 | RCA Televison & Video
Screen looks like 3d convergence is off bow in the screen
you might have the fl231 fuse promblem. which is common and inexpensive to fix read this article and let me know if it helps http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in
Dec 26, 2010 | RCA P52950 52" Rear Projection Television
Have rca tv combo unit have rca universal [rcu600m] cant seem to
RCA 000,006,011,019,027,034,038,044,046,088 <-----codes
Programming a Device using Code Search:
1. Manually turn ON your device (TV, VCR, Cable Box)
2. Press and "HOLD" CODE SEARCH
3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the device turns off, press and release ENTER.
7. With the device on, press any other button.
If the device responds, no further programming is required.
If the device does not respond, repeat steps 1-6.
Nov 09, 2009 | Televison & Video
RCA Universal Remote Code For A Trinitron Xbr Tv
There are several RCA universal remote models. With out your specific model # I can only give you the most common code. 002.
You can also try the steps below to use the internal code search mode if your remote has this feature.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Oct 23, 2009 | RCA Televison & Video
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Sep 07, 2009 | RCA Universal Remote Control
Remote control codes
  • TV-000
  • VCR-000
  • Cable Box-000
Find codes for device and brand below.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  3. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
RCA Codes for VCR
000,005,007,008,028
035,037,054,069
Nov 04, 2008 | RCA VR557 VHS VCR
RCA Universal Remote set to my Emerson TV
  • TV-000
  • VCR-000
  • Cable Box-000
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
RCA Universal Remote Control Code
sony code is 002
Dec 16, 2007 | RCA 244889 Remote Control
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 25GT511 - fuzzy picture slight static sound; wiggle coax rear mount temp resolve
There might be a bad (loose) connection in the RF isolator or the tuner (both are silver boxes. Try to unplug the coax and bend the RCA tabs in so that the connection gets firmly made when reconnected. This may help. If it does not The connector may have to be replaced.
Aug 08, 2007 | RCA 32V550T 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
