Question about Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803
Minute hand on my Professional is Lose
I noticed today the minute hand gets stuck when I try to set the time and if I tap the watch it swings in the increment of 10 minutes back or forth at the opposite direction of the tap. I do recall banging it against the window sill last night as I almost slipped on Ice- could that have caused the minute hand to come lose?
Most likely the impact did loosen it. I suggest you take it to get it opened and adjusted before the teak causes internal problems.
Posted on Mar 18, 2008
  • albert51r Mar 18, 2008
    Good luck and i hope you can fix it. dont worry it no biggy
70's Era Automatic 2686 minute hand gets stuck
It sounds as though the minute hand is not parallel to the watch face and is getting caught on the hour markers (or 'batons') - it's probably a little loose or maybe slightly bent.
It should be a relatively easy fix but it requires skill and knowledge to do it - not difficult for a watch repairer but close to impossible for your average man in the street.
If you value this watch, take it to a professional to sort it out.
Oct 07, 2017 | Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    Mintues hand problem.
    There are two reasons for this. First- you distorted minute hands hole and now it is not sitting tightly on pinion. Second- when you pulled off the minutes hand, you lifted cannon pinion. As the result it is loose and swings freely. I do understand you have no knowledge how the watches are build, so, visit your nearest watch repair shop and ask to fix it. Please, do not take it personally - it is just because you can't do that without watchmakers knowledge, so, save your nerves, time and watch. Rate me, plz.
    Mar 18, 2010 | Timex 27191 Wristwatch
    Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
    First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
    Jan 28, 2010 | Watches
    Free roaming second hand
    This sound like a job for the professionals.
    I advise you to take it to a watch repairer.
    Jan 28, 2010 | Fossil VT2657 Pocket Watch
    Analog hands lose time when worn.
    This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
    Nov 23, 2009 | Casio AMW320R 1EV Casual Sports Watch
    I have not worn my SEIKO kinetic wrist watch for a
    Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
    Jun 05, 2009 | Seiko Kinetic watch
    The second hand is not moving
    Got the same problem guys. i have one of the new electronic diving eco drives.
    First time i managed to get it going again, by forcing all the hands to the top for diving mode, then back to normal, this action ´nudged´the minute hand back into motion, but a little later it stuck again at the same spot.
    I guess mines going back to the factory, and i´m gonna b watchless for a few weeks :(
    Jan 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
    Aquaswiss trax watch
    AQUASWISS TRAX MODEL:
    For clarity:
    There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
    Top knob: #1
    Middle knob: #2
    Bottom knob: #3
    To adjust the stopwatch feature:
    1. Turn #2 counter-clockwise until it pops out to its adjusting position.
    2. Pull #2 towards the right until you feel the first click. (There are two click positions).
    3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
    Now you are ready to calibrate the stopwatch feature.
    4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
    5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
    You are almost done.
    6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
    Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
    7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
    8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
    9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
    During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
    Your watch is ready to use.
    The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
    Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
    Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
    Hope this was helpful!
    vsndesigns
    http://www.rgmarchitect.com
    Dec 20, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
    Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803 Logo
    301 people viewed this question
    Top Tag Heuer Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
