Ol code is for over load. Too many clothes. Sometimes you will get this code with nothing in the tub and the water keeps filling then goes to drain. if this is why your asking then pull the back off the washer and pull the clear tube off the tub. Blow in the tube and then the washer will take off and start operating correctly, Well till you stop blowing. This is a pressure problem and air is leaking right there at the tub and tube. I suggest a little plumbers dope and put the hose back on. if machine does not return to normal then you got a little dope in the air way. Pull the tube and replace again. Wa La!
What are the error codes for a Whirlpool Cabrio washing machine?
is that the letter O or the number?
