Question about Toshiba TP55H60 55" Rear Projection Television
Toshiba 55inch rear projection.
This tv (tp55h60) will work fine for about fifteen minutes and then shuts it self of and the red power indicator light starts flashing at a steady slow rate. if i unplug the tv and plug it back in it comes back to life.i'd like to fix it myself and i just need help with diagnosing the problem. i i have repaired lots of automotive components over the years and feel like this is something i could handle with a little help.
  • peoriatwins Apr 03, 2008
    I had this problem continually with a previous model. It was all fixed under warranty and had to be done by a pro.
OK. I changed the fan and then the lamp. Still won't turn on. I can change stuff myself. Just only tell me what to change please.
Posted on Feb 09, 2012
  • Toshiba Master
  • 5,568 Answers
You should be able to hear a fairly quiet fan when listening at the rear of the set. The high intensity CRTs used in projection sets run very hot so if the fan stops, eventually the set will shut down to prevent heat damage.
Posted on May 04, 2010
    Problem Solver:
  • 12 Answers
Check your connections to make sure they are not loose, also if you pull the boards check for burnt solder points. I have parts that are good if you want them, very cheap. Email me at hill6399 at yahoo.
I have a toshiba tp55h60, power light is flashing
I have the parts you need if interested. Email me at hill6399 at yahoo.
Oct 30, 2009 | Toshiba TP55H60 55" Rear Projection...
TV TURNS ON AND OFF BY ITSELF
check the fuses, I have the parts if you need them. hill6399 at yahoo.
Oct 22, 2009 | Toshiba TP55H60 55" Rear Projection...
Toshiba tv model # tp55h60
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
Toshiba projection tv
Unplug the TV from the outlet for about 30 seconds. This will reset the microprocessor. Re apply AC and power on the TV. If your lucky the set will come on and play. If not, the red light will start blinking again indicating shutdown. There are many reasons for the set to go into shutdown, but one of the most common cause is failure of the convergence output IC`s. If your TV is in shutdown, you will need to find a qualified technician for proper diagnosis and repair.
Nov 23, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba TP55H60 power down after start up
Try the following
1-unplug tv
2-remove bottom cover on tv
3-tap the power supply frame a few times (where the power cord enters the tv)
I had the blinking red light on my tv. I tried other solutions like removing the red wire a few times etc. Tapping the power supply frame solve the problem.
Aug 11, 2007 | Toshiba TP55H60 55" Rear Projection...
Design Problem of TP55H60
call tech ..suggest soldering h-drive.
Jul 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Toshiba TP55H60 55" Rear Projection Television Logo
120 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
