Question about Dell Dimension 2400 PC Desktop
Speakers have no sound
Turned off the computer speakers and no sound comes out now that I turned them back on.
  • 148 Answers
Uplug speaker cable and plug it again
Posted on Mar 17, 2008
My speakers make a sound when everthing is turned off
what you are probably hearing is a form of mains interfearence. the only to stop the sounds coming out is to unplug them from the mains.
Best of luck
Oct 24, 2011 | Bose Companion 2 Computer Speakers
I hooked up the speakers to the back of the PC with the matching green plug in. The speakers are on and working but no sound is coming out. I also clicked on the speaker icon and turned the volume all the...
The first thing to do is to determine if it is the speakers or the computer that is having issues. Plug the speakers into an MP3 play, disk player or some other audio device that has a headphone jack and verify they work. If they do, then you need to determine why the computer is not sending sound to the jack. When you right click on the speaker icon, and select "Open volume mixer" there should be multiple sliders to turn up. Make sure the internal speaker/headphone jack volume is up (and mute not selected) as well as the "applications / windows sounds" volume. comment back to me if you require further assistance and if so, include the model computer and operating system in your comments. Good-luck - Subdriver
Feb 15, 2010 | Logitech X-140 Speaker
My computer tells me that my speakers are not hooked up but i looked and made sure they were and there was still no sound coming out of my speakers. what do i do to fix it?
Look at the back of the speakers and see if there is a mains power cord coming out of them, if there is make sure that the cord is plugged in properly and the power turned on.
Check all the wires on the back of the speakers, make sure they are all plugged in.
Take the speaker plug out of the compute and plug it into another device. ( mp3 player or radio)
If they work in that device, there could be a problem with the sound card in the computer.
If they don't work in the other device the speakers might be broken...
Jun 24, 2009 | Cables Unlimited (SPK-VELO-001) Computer...
Can i add any speakers to my dell vostro 200?
No you don't. As long as you can plug the speakers to the green port on the back of the computer, the speakers are powered and the volume knob on the speakers is turned all the way up. You should hear sound.
Also make sure the sound is not muted in windows.
Sep 27, 2008 | Dell A215 Computer Speakers
5.1 surround not working
I uninstalled the previous audio software that the computer had. (Realtek HD audio) and turned off the onboard sound card in the BIOS settings. Then I went back and uninstalled all the new audio software and reinstalled it with all antivirus programs turned off. The main trick was to make sure that the matrix is turned off. If it is on it will play sound from all the speakers at once as if it were mono. Turning it off after changing the BIOS and uninstalling the old software and reinstalling the new allowed it to work properly. I hope this helps.
Sep 10, 2008 | Logitech Z-5300 Computer Speakers
No sound
This issue could be caused by any of the below reasons.
  1. Sound card does not work
  2. Speakers are not connected properly
  3. No power to the speakers
  4. Volume on speakers turned down
  5. Volume on sound card turned down
  6. Bad hardware
  • make sure the speaker setup is correct. It is possible that during an installation of another program that the speakers software setup was changed causing issues with your sound. To do this follow the below steps.
  1. OpenControl Panel
  2. Open "Sounds and Multimedia Properties" or "Sounds and Audio Devices" in Control Panel.
  3. Click the "Audio" tab
  4. In the Audio tab click the "Advanced" button under "Sound Playback."
  5. In the Advanced Audio Properties window make sure your speaker setup is correct. If you're not sure what to set this setting as, set it to the default "Desktop Stereo Speakers" option.
  6. If you changed this setting click "Apply" and close out of all windows.
  • Ensure that the sound card works properly by connecting either another pair of speakers to the computer, or a pair of headphones.
  • the left speaker will generally have a cable that cannot be removed from it. This cable should be connected to the other speaker (generally this cable has no color or is white / gray). The next cable is the line out cable, it is generally green in color and should go from the right speaker to the line out hole in the back of your sound card.
  • Finally, the power cable generally should be connected to the back of the right speaker, or in some cases, the sub woofer. The power cable can vary; while most speakers are in the above configuration, some speakers may also not utilize a power cable connection but instead have batteries, while other speakers that connect to the side of your monitor may use a portion of the power from the monitor itself (via another type of cable).
  • Most speakers will have a small LED (light) indicating if the speaker is on. Verify that if this light is present that it is illuminated.
If no LED is seen or the speakers don't appear to be getting power, verify the power cable is properly connected to a working outlet or if your speakers use batteries that the batteries are good. Finally, most speakers can be turned on either by using a button or by moving the volume knob from left to right.
  • Verify that the volume knob on the speakers is properly turned up. If you are un-certain what direction to turn the knob, play a long sound file or CD and while the sound is being played, adjust the knob left to right or up to down.
  • The sound is also able to be turned up and down through the software installed on the computer. Verify the sound settings in the software are properly turned up.
  • Finally, if all of the above recommendations do not resolve your issue and connecting another pair of speakers or headphones to the computer does work, it is likely that the speakers are bad. It is recommended that you contact the manufacturer of the speakers or computer for a new replacement.
Jul 16, 2008 | Audio Players & Recorders
Speaker creative sbs340
check control panel, and see if sound is configured for your external speakers. Some screwup may have occured, leaving your computer speakers turned off, and your external speakers not comfigured.
Mar 09, 2008 | Audio Players & Recorders
Logitech z-540 no sound
Here are a few basic steps. they seem abit logical but just have a double check on them.
1. Check that you speakers are plugged in.
2. That the wire going into the back of the computer is going into the green imput (that is for the speaker sound to come out)
3 If you have a combination of speakers make sure they are all wired properly.
If your sure all the wiring is right. Check to see if the volume on the status bar at the bottom left of your desktop is turned on. This will be a small speaker double click on it, check to see if the volume is turned on.
If all this is correct it may be a driver problem. If so come back and let me know and I will guide you through the drive troubleshooting for this.
Sean
Dec 10, 2007 | Logitech Z-540 Computer Speakers
Durabrand uc-280 don't work!
go to device manager locate the speakers, right click and update drivers, if that fails search google for that sound card driver.
Nov 12, 2007 | Audio Players & Recorders
Dell Dimension 2400 PC Desktop Logo
43 people viewed this question
Alun Cox
