Question about Digi-Tech DOD-Digitech 231 - 31 Band Per Side Equalizer Home Equalizer
Expression pedal After I upgraded my firmware for the RP 250 to version 1.9, my expression pedal will not work.
  • 1 more comment
  • Anonymous Sep 14, 2008
    my rp 90 expression pedal doesnt work but hte effects do
  • Anonymous Mar 21, 2009
    ive had my rp 90 for a few months and i was playing around with the settings and next thing i realize is my expression pedal doesnt work but my effects do. does anyone have a solution to fixing this problem? cause i know its not broken
  • Anonymous Apr 29, 2009
    ya me 2 my rp250 did that etzact same thing
How to connect an expression pedal to a Boss gt-3
Just plug FS-5U or FS-5L or EV5 / FV300L (Roland),or other external switch to SUB EXP PEDAL.
You can also use pedal switch that you create by yourself.
Use stereo phone jack and cable.
It can be function for 1 or 2 switch.
Setting function for SUB-EXP-PEDAL is at UTILITY-GLOBAL menu.
You can set switch 1 or 2 for what do you want to function each switch at the external pedal.
If you want to connecting external expression pedal (FV300L),just plug it to SUB-EXP-PEDAL. Setting is same as above.
Aug 31, 2015 | Boss Music
My Wawa pedal went out on my Digitech RP 500 how could I make it work again
This might work - Hold the bypass switch for five seconds and follow the on screen instructions to calibrate the expression pedal. If that doesn't work you could also try doing a back up and then a factory reset. You may also consider a separate wah pedal. There are many recommendations at:
What Is The Best Wah Pedal For The Money Our Answer For You
Jan 07, 2015 | DIGITECH RP500 Guitar Multi-Effects Pedal
Hi. I have bought a Behringer Bass Synth BSY600 and a Boss FV-300L Volume / Expression pedal. Both work on their own but i can't get the Expression pedal to work with the Bass synth. The expression...
The FV300l WILL NOT work tying it into the EXP of the BSY600. What you need to do is to run your guitar into the IN of the BSY600 and use TWO audio cables from the BSY600 output, the OUT and the DIR out and run those into the two IN's of the FV-300L. Then use whichever function by connecting the two OUT''s of the FV-300L to two channels of the mixer or a two channel amp so you could proportion the BSY600's effects as desired. You could also just use whichever out from the FV-300L you want which originates in the BSY600. The BSY600 is made to use an expression pedal that is a single TRS plug which is simpler, but you can use your FV-300L as I have described just as well, it just can't use the EXP input of the BSY600.
Jun 22, 2011 | Behringer BSY600 Bass Synthesizer Ultimate...
Hi I have a Behringer Fcb1010 and I want to programme one of the expression pedals as a volume pedal but am unsure how to do this?
I have Behringer Fcb 10 10,but i want to know how expression pedal volume work when connect with GR55.
Feb 11, 2011 | Behringer Fcb1010 Midi Foot...
I have a digitech rp 255 effects pedal. everything works except the expression pedal. it acts as if its not part of the unit. it controls the volume and a wah sound. but it stopped working. i kno that it...
This happened to me. First, do the factory reset. Then, recalibrate the pedal. All of this can be found in the owner's manual on pages 40 to 42. Here's the link to the manual:
Dec 23, 2010 | Audio Players & Recorders
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
Microsoft office 2007 key doesn't work for full version
this is the main one to launch if it asks..and those are for the each one in part ..
KGFVY - 7733B - 8WCK9 - KTG64 - BC7D8
Microsoft Office Enterprise 2007:
F3DJD-6FFQ4-XQTQF-PGK47-8MDQ8
Microsoft Office Visio\Project Professional 2007:
HCFPT-K86VV-DCKH3-87CCR-FM6HW
Microsoft Expression Web:
DDWJC-VFGHJ-7GFK6-9QK3D-PFTHW
Do not forget to rate ..please..!
May 26, 2010 | Microsoft Office Word 2007 Upgrade Version...
Expression pedal wont work
Here is a link with a source for the manual on the right of the page:http://www.digitech.com/products/Bass/bp200.php Further information can be found at support at the top of the page.
Mar 20, 2010 | Music
Low volume allen organ adc 4600
IF the expression pedal uses a lamp and light-dependent-resistor, check for burned out lamp at the pedal.
Sep 06, 2009 | Music
I have a problem of loading in MS Express Web Design. Most of the time the program would crash everytime I open a file. Note that I use Window Vista.
Try to re-install your MS Expression Web and make sure that your hardware meets your software requirements for MS Expression Web. It is the major factor why this program crashes while loading or opening it.
Regards!
Jul 05, 2009 | Microsoft Expression® Web® Full Version...
Open Questions:
203 people viewed this question
Top Digi-Tech Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Digi-Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
