Question about Dishwashers
Spray arm for Maytag dishwasher
The spray arms on my dishwasher have "stuff" inside them and it is near impossible to get it out through the little holes. Is there a way to pull apart these arms? I have a Maytag Jet Clean II MDB7600aw.
  • lrtd Mar 17, 2008
    Yeah, that's what we have been doing but seems like there should be an easier way to do this. Thanks
    President:
  • 2,651 Answers
Altough you cant seperate them loosing hte little to nut will allow you to remve and alittle patience you'll be able to swish them around and through larger center mounting hole. the only other option is to replace the arm p/n 99002678 just under 20 bucks
Posted on Mar 16, 2008
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Maytag free standing dishwasher. The machine fills fine, goes through entire cycles with the spray arms spinning but the water does not pump through the spray arms.
Hello, look at the little holes in the spray arms and see they are pluged. If so, clean the holes wiith a small pick. There are chemicals that can be run through your dishwasher to keep the hole and other stuff from pluging up with scale. I hope this help you. GB...stewbison
Sep 23, 2011 | Dishwashers
How do I clean lower spray arm of Maytag Dishwasher model DWU8260?
They are virtually impossible to clean so that they work properly again....
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 13, 2011 | Maytag Dishwashers
Upper arm not getting any water
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 27, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
The holes of the spray arms of My admiral dwd1500aww dishwasher seem clogged. What's the best way to unclog the spray holes?
I have been there and it is darn near impossible to clean those holes out and get the **** out of the inside of the arm...
you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 04, 2010 | Maytag Dishwashers
Dishwasher Fills and drains bu does not clean, like arms don't move , also makes a roaring noise
That problem can have many and varied solutions...I have tried to put together in this tip the most common and easiest to checkout problems. For many of the spray arm problems the solution will be here, but it would be impossible to cover every possible problem in any answer with out actually being able to hands-on disgnose the problem....
Dishwasher2_bing.gif Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
Jun 22, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Top spray arms dont work.
Most likely you have debris blocking the holes in the spray arms. The spray arms can be removed and cleaned out in your sink. (blocked holes in the lower spray arm arm almost impossible to clean out)
Jun 05, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Upper rack spray is clogged
it has a pressure insertion fitting that snaps into the arm thru the hole,you need to press in on the ears on the bottom of the are to release the plastic grips to let it drop out,then the arm should remove after this
Apr 19, 2010 | Maytag MDB5100A Dishwasher
Want to know how to clean the arms
here is a breakdown of the inside of the machine. if the spray arm is not plugged, check the filter screen for debris. also check to make sure the wash impeller is not bro250ken. hope this helps a little.
Oct 24, 2009 | Maytag MDB7100AWB Dishwasher
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
