Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It overheats and pops the Xl-2100u lamp? - Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Apr 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
3691
Points
14
By pops? do you mean it explode? how many lamps? it could be the fan that supposed to be ventilating the lamp or it could be the the ballast, why the ballast because the ballast regulates the voltage in order the keep the lamp on, for ignition it sends around 15,000 volts after that it regulates the votage to a small amount of voltage around 5,000 so it could be sending the big amount of voltage all the time never regulates that or it could be regulating and then sending another big amount of voltage over and over until the lamp doesnt handle those changes.
derbed
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Apr 05, 2010
derbed
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
9266
Points
49
RPTV Lamp for Sony LCD
P/N
A-1606-034-B Description Replacement lamp for Sony Grand WEGA or XBR Grand WEGA rear-projection LCD television Lamp model numbers: XL-2100U and XL-2100. Compatible with the following models: KDF-50WE655, KF-50WE610, KF-60WE610, KDF-42WE655, KDF-60XBR950, KDF-70XBR950, KF-42WE610, KF-42WE620,Installation requires a 3mm Allen wrench Specifications Lamp: UHP Lamp, 120W Dimensions (WxHxD) - Approx. 3 5/8" x 3 7/8" x 4" (92 x 97 x 100mm) Weight - 11 oz. (310g) LFL Retail Price: $87.00
If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it is time to replace the lamp with a new one (not supplied).
Use only a replacement Sony XL-2200U for your TV. Use of any other lamp may damage your LCD projection TV. Contact your Sony dealer for a replacement lamp.
Please refer the "Replacing the Lamp" section in your TV model (KDF55WF655 | KDF60WF655 | KDF55XS955 | KDF60XS955 operating system manual for step-by-step directions for replacing your TV's lamp.
Note: Before replacing the lamp, turn the power off on the main unit. Wait several minutes, then unplug the power cord. (The cooling fan will continue to blow for about two minutes after turning the power off.)
Be sure to allow the lamp to cool down completely before removing it. The surface of the lamp remains extremely hot for at least 30 minutes after the power has been turned off.
Anonymous
Level 3:
  • Master 10,594 Answers
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957435
Points
33084
No, tv has temp sensor to monitor heat and fans to cool lamp.
When lamp in dlp tv reaches to its working life that is approx 2500 to 3000 working hours, lamp gets break.
Let me know, is it new lamp that got pop?
Is it Sony original lamp or an aftermarket/ cheap lamp?
  • Anonymous Sep 30, 2010
    Hello I think I have the same issue but my screen would flicker as if it was going off then on and this tool all but 2 sec to flicker. but it would only happen after the tv has been on for like 20 mins or so. My quick fix was to put a house fan behind the TV and blow air into it. but before I put the fan I noticed that it was very hot behind the tv. could this be the cooling fan issue and if yes how do I fix it and which one is the one that is not working? since I put the fan the problem is gone. but I don't want to always use the fan to cool it.
    In my opinion, you should check exhaust fan that blow hot air of lamp out of tv, this fan seems running slow.
Red light blinks 4 times
Hi,If your tv is close to 6000-8000 hrs or 2-4 yrs and haven't replaced the lamp yet, it might be time.The part # is XL-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm and here's the instructions to replace it: http://www.fixyourdlp.com/guides/sony/XL-2100U.php
Black screen with sound on xbr grand wega 70 inch
Hi,If tv is between 6000-8000 hrs 2-4 yrs and havent replaced the lamp it might be time to do it so.Here's your part # XL-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm here's instructions to replace it : http://www.fixyourdlp.com/guides/sony/XL-2100U.php Thank you and have a blessed one!
2answers
I have a sony wega 46 inch tv model number: KDF42WE655 the screen went black and the red light came on where it says "lamp" on front of tv Does this mean I just need to replace the lamp?
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.But pretty much it does sound like the lamp.your part # will be xl-2100 and you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm and here's the instructions to replace it: http://guides.fixyourdlp.com/sony/XL-2100U.php Have a blessed one!
1helpful
The red lamp light is flashing on our Sony KDF42WE655. What is the replacement parts I need to fix and instructions for doing so. Thanks.
You can find the documentation for your Sony on the Sony Documents & Downloads page.
The part is Sony XL-2100 or XL-2100U. Instructions are in the manual, page 16.
The tv made a "pop" sound and turned off, now when I turn on the tv the screen is black and there is a buzzing sound, Is the a bulb issue?
Yes Lamp is Bad and Buzzing sound is Ballast board spark cap arking. Lamp is a XL-2100U Fox has them for $109.00 other companys want $215.00 for it
1-800-227-5369
1helpful
Middle of the looks yellowish what could be the problem
the light filter for the blue lcd is fried and needs replacing. common problem with units that are dusty and overheat. unfortunately, many companies don't sell individual parts for the optical engine (where the filter is), so you may have to get the whole engine.
Xl-2100u
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your Projector from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your unit Caution: Do NOT touch the bulb directly with your fingers.
  • 0helpful
    Need sony lcd tv projection lamp. xl-2100
    You can but XL-2100 Lamp at Sony Accessories and cost is $200
    Please enter part number " A1606034B " LAMP BLOCK XL-2100U in search box and see details.
    Thank you.
    Help for Sony XL-2100U Projector lamp
    If you need XL-2100U Lamp for your Sony Grand Wega, its available on Sony Accessories and its price is approx $200
    Here is bit details of required part from Sony web site...
    Part Number is ... A1606034B LAMP BLOCK XL-2100U
    Compatible Models
  • KDF-42WE655
  • KDF-50WE655
  • KDF-60XBR950
  • KDF-70XBR950
  • KF-42WE610
  • KF-50WE610
  • KF-60WE610
  • Need further help, let me know.
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
