Question about NEC MultiSync 1770NX 17" LCD Monitor
Video input: 2 D-sub No signal /Video input 1 DVI-D No signal
NEC MultiSync LCD 1770GX
Good Afternoon...
I have had a NEC Monitor for quite some time now giving me a new signal error...Video input 2 D-sub No signal and/or Video input 1 DVI-D No signal.
What to do?
Help!
Thank you
John
  • Bud Martin
    Bud Martin May 11, 2010
    Does it do the same with another PC? Just need to narrow down the problem before start taking the monitor apart.
  • 95 Answers
SOURCE:
My monitor suddenly went black when I awoke it from standby and it only states "video input 1 D - SUB NO SIGNAL" each time I turn the moniitor off an on again. I checked all connectivity to the...
My suggestion is going to be if you have another computer that you can hook up to the monitor and see if it works for it then the problem would be not the monitor but your computer. As it is telling you that it is not recieving a signal. If it still doesn't work then it will be something wrong with the monitor or the cable connecting it.
Jun 20, 2011 | NEC MultiSync 1770NX 17" LCD Monitor
WHAT ADAPTER DO I NEED FOR MY NEC LCD 1920NX
it is stated that it has vga input.
what are you trying to use it for?
if you are trying to use the dvi input and only have a a vga output on your computer you need a vga to dvi adapter
Sep 06, 2010 | NEC MultiSync 1920NX 19" LCD Monitor
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
What cable do I buy
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | NEC MultiSync 1525X 15" LCD Monitor
I have an NEC Multisync LCD 1770GX monitor. Is it possible for something to interfere with the display? I see screen distortion on and off during the day. It looks like 'snowy' flickering that mostly...
Cables usually give up first. If you can substitute the cable or another monitor try that. If you see the same thing on the monitor, you have eliminated the cable. If you have another monitor you can beg borrow or steal from a friend, try doing that. If the problem still follows, then you have eliminated the monitor and the video card is the only thing left. If your PC has a built-in video card then the motherboard is toast
May 10, 2017 | NEC MultiSync 1770NX 17" LCD Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Help Please!
power supply is bad on one of its legs(12 volt or 5 volt) you can have that bench tested at a service center or use a volt meter to check the output on the cables probably the 5 volt as the agp and the dvd roms cdroms etc need 5 volts to operate
May 01, 2008 | NEC MultiSync 1760NX 17" LCD Monitor
Monitor not coming on at all
i think the memory or the graphics card of your system unit have loose contact try to remove it from the slot and
insert it back again.im sure 100% it gonna work.
Mar 11, 2008 | NEC MultiSync 1770NX 17" LCD Monitor
Can't use DVI with monitor
You have 3 ports on your graphics card(VGA - 15 pin D-Sub x 1, DVI x 1, and S-Video x 1)Now if you want to use DVI just connect the DVI port to your monitor thats all..
Enjoy!
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
NEC MultiSync 1770NX 17" LCD Monitor Logo
5,194 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
