Question about Cobra 22 CHANNEL 2-WAY RADIOS
Help hi i need user manuel; for cobra pr4700wx radio it is on vibrate i cant get it off
  • jake47 Mar 17, 2008
    thank you very much maybe one of the radios is busted i can talk and and send call but i hear nothing when i call that radio
    Brigadier General:
  • 6,966 Answers
Hi again,
It would seem that you posted twice. As responded to in your other post, the manual is here.
Cheers.
Posted on Mar 17, 2008
  • Louie  Role
    Louie Role Mar 18, 2008
    Hi again,
    I am assuming that you have downloaded a copy of the manual and worked on your "vibrate" concern.
    As to your next concern of receive audio on one of the radios, may I suggest you post it as a separate problem. We get rated on a per problem basis.
    Additionally, if agreeable to you, pls add me up as a Tech Buddy, post that problem directly to me that I may personally address that particular concern.
    Incidentally, your first concern was the manual & vibra and I am of the opinion that I have answered both, Notwithstanding your next concern (receive audio on one of the radios), I was wondering if you would reconsider the rating you have given the initial solution.
    Again thank you for using FixYa.
Lost owners manuel
Hi go to
http://cobra.com/downloads/manuals/29LTDCLA.PDF
If this helps please rate me
Jun 30, 2010 | Cobra 29 LTD CB Radio
Require instructions to fit cobra 7928 car alarm
hi tony, im tony as well, i just bought a car with a 7928 fitted and after an hour searching chat rooms and web sites found the manuel its available here http://dl.owneriq.net/2/27538fd6-de8c-4da4-9f07-b5b4fc353a82.pdf if you cant find it search google for cobra 7928 user manual
May 15, 2009 | Vehicle Parts & Accessories
No Auto Squelch on Cobra PR4700WX
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
Dec 24, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
COBRA PR4700WX
Hello horndog78,
Your radio may be locked. You can confirm this by looking for a icon of a padlock on the screen.
To toggle the lock on and off hold down the LOCK/MODE button for a full two seconds until you hear a double beep.
Best Regards,
Ken
Go Ahead. Use Us.
May 02, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Stucxk on vibrate
As per instructions of the manual:
"...Your microTALK® radio can alert you to incoming signals by
sounding an audible call tone, by vibrating silently or both. To change call settings:
1. Press the Lock/Mode button until the Call Setting icon flashes on the display. The current setting (“01” vibrate + ring, “02” vibrate only or “03” ring only) is displayed.
2. Press the Channel Up or Channel Down button to change the call setting.
3. Choose one of the following:
a. Press the Lock/Mode button to enter the new setting and proceed to other functions.
b. Press the Hi•Low/Enter button to enter the new setting and return to Standby mode
Should you need a copy of the manual, it is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Misplace users manual
You can download a copy of the owners manual from the Cobra site. The file in in this page PR4100-2WXVP. You would need Adobe Acrobat Reader to access the file.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Jan 18, 2008 | Cobra PR4100-2WXVP 2-Way Radio
User manual
Go To http://shop.giantintl.com//Manuals.asp and right in the center of the screen there will be a pull down menu, select the T8500R in the pull down menu. Models T8500/T8510/T8530 and T8550 are all on the same owners manual, good luck!:)
Dec 01, 2007 | Radio Communications
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Open Questions:
Cobra 22 CHANNEL 2-WAY RADIOS Logo
202 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
